#1 2016-09-04 12:09
Jerome
Dictionary software?
I was looking for some dictionary software and found goldendict which seems to be well regarded. Unfortunately after installing (with apt-get) and running it I got a segmentation fault. sad
Any other suggestions?
update: I installed kdict which does the job.
#2 2016-09-04 13:39
Re: Dictionary software?
Looks like a Debian bug, as we have quickly tested to run goldendict under TDE and LXDE desktops. Both attempts to run goldendict endup with segfault. We will report a bug at Debian bug tracker.
#3 2016-09-04 13:57
Jerome
Ok, sadly kdict-trinity also crashes. So I'm looking for another alternative. I would prefer to download a database so that I can use it offline.
#4 2016-09-04 17:41
You can use goldendict, there is a workaround available. Run in terminal:
$ KDE_SESSION_VERSION=4 goldendict
#5 2016-09-05 09:58
Jerome
Great, thanks!
#6 2016-09-07 09:03
The issue is now fixed in Q4OS. You can run goldendict without the workaround after the system update.
