#1 2016-09-02 12:19
[Solved] Warnings after adding repository
I have added a repository using command sudo qrepoadd deb-multimedia. After typing sudo apt-get update i have warnings which are shown in attachment. How can I fix them?
#2 2016-09-02 12:56
Re: [Solved] Warnings after adding repository
You should remove added repository, as it already exists in your system. Type in terminal:
$ sudo qreporm deb-multimedia
