#1 2016-07-09 18:44
vijay1700
Problems I am facing!
Here are the issues I am facing:
1. Takes more than 1-Min for booting!!!
2. Does not merge folders and have to overwrite. This makes time consuming since I need to overwrite already existing folders thereby overwriting all the files inside each folders.
3. Icon View does not work properly.
4. Bluetooth ON's automatically!
5. Every time, I have to use open with VLC Media Player for opening .webm files!
6. The OS has taken entire HDD as its partition and is NOT allowing me to partition at all using GParted.
Any solution?
#2 2016-07-10 09:12
Re: Problems I am facing!
ad1
May be this issue ?  http://www.q4os.org/forum/viewtopic.php?id=383
ad2
Konqueror file manager doesn't have this feature, however you can install and use any other file manager from repositories.
ad3
We are not able to reproduce, please specify more exactly.
ad4
We are not able to reproduce, may be hardware dependent issue.
ad5
Navigate Konqureror file manager to any .webm file -> right mouse click on the file -> Properties -> Settings button on the right side of the dialog -> Set Application preference order
ad6
We are not able to reproduce, GParted resizes all Q4OS partitions fine. If you would want resize partitions you have to boot from CD or USB and resize unmounted disk partitions. If you would want to specify partitioning during Q4OS installation, use live CD or classic install mode.
