#1 2016-06-05 14:44
aldrik
[resolved] program to launch
Hello all,
I have a little question, not easy to explain :
I have the two Q4OS installed. I used Telegram and I lauch it on Krusader.
In Q4OS stable that's OK. In Scorpion I can't do this, with the same way and options.
Any Idea ?
Have a good day
Aldrik
#2 2016-06-05 18:29
Re: [resolved] program to launch
I just checked and I could not launch the app via double clicking the file, but the app works when typing
./Telegram
from a terminal (konsole) when you are in the correct directory of course.
You can of course put this file into /usr/bin (or another directory from your path) and just type "Telegram" from the command line at any time.
Alternatively if you right click on the desktop and select Create New -> Link to Application Give it a name (Telegram) in the first screen, and then select the application tab and locate the file by clicking Browse on the Command line, save it and then just double click your newly created desktop icon and it should start.
#3 2016-06-06 15:19
aldrik
Thank you !
That's ok !
I'm just surprise : in orion it's ok and in scorpion not...
have a good day smile
#4 2016-06-06 15:24
I think there are some changes to file handling or something as I couldn't start a script in the startup folder and had to create a desktop file to run it. Glad you got it sorted though. smile
#5 2016-06-06 15:41
Keep in mind, Scorpion is a testing version.
#6 2016-06-06 17:35
aldrik
Hello Team !
It is a great version... then i forgot it's only testing !
Have a good day smile
