#1 2016-05-04 10:44
Installing imagemagick says I have software to be removed
I wanted to install imagemagick and from the commandline typed
sudo apt-get install imagemagick
And was surprised to see all this
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  binutils-dev checkinstall cmake cmake-data comerr-dev cvs esound-common gettext-kde krb5-multidev libacl1-dev libapr1 libaprutil1
  libart-2.0-dev libarts1-trinity-dev libartsc0-trinity-dev libasound2-dev libaspell-dev libattr1-dev libaudio-dev libaudiofile-dev
  libavahi-client-dev libavahi-common-dev libbotan-1.10-0 libbz2-dev libcups2-dev libcvsservice0-trinity libdbus-1-tqt-dev libesd0
  libesd0-dev libgpgme11 libgssrpc4 libidn11-dev libilmbase-dev libjasper-dev libjbig-dev libjpeg-dev libjpeg62-turbo-dev libkadm5clnt-mit9
  libkadm5srv-mit9 libkdb5-7 libkrb5-dev liblcms2-dev liblua50 liblua50-dev liblualib50 liblualib50-dev liblzma-dev libmad0-dev libmng-dev
  libogg-dev libopenexr-dev libpciaccess-dev libqt4-assistant libqt4-webkit libqt5concurrent5 libqt5declarative5 libqt5designercomponents5
  libqt5opengl5 libqt5qml5 libqt5quick5 libqt5script5 libqt5webkit5 libqt5x11extras5 libr-dev libsasl2-dev libserf-1-1 libssl-dev libssl-doc
  libsvn1 libtiff5-dev libtiffxx5 libtqt3-compat-headers libtqt3-headers libtqt3-mt-dev libtqtinterface-dev libudev-dev libvorbis-dev
  libxkbfile-dev libxml2-dev libxmu-dev libxmu-headers libxslt1-dev libxt-dev lua50 mc mc-data qml-module-qtquick-controls
  qml-module-qtquick-layouts qml-module-qtquick-window2 qml-module-qtquick2 qt4-demos qtcreator qtcreator-data qtcreator-doc reprepro
  tdecachegrind-trinity tdelibs14-trinity-dev tdevelop-data-trinity tdevelop-trinity tdevelop-trinity-doc tqt3-apps-dev tqt3-assistant
  tqt3-designer tqt3-dev-tools tqt3-doc tqt3-linguist tqt3-qtconfig uuid-dev valgrind valgrind-dbg x11proto-dri3-dev x11proto-fonts-dev
  x11proto-present-dev x11proto-resource-dev x11proto-scrnsaver-dev x11proto-video-dev x11proto-xf86bigfont-dev x11proto-xf86dri-dev
  xfonts-terminus xserver-xorg-dev
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  imagemagick-6.q16 imagemagick-common liblqr-1-0 libmagickcore-6.q16-2 libmagickcore-6.q16-2-extra libmagickwand-6.q16-2 libnetpbm10 netpbm
Suggested packages:
  imagemagick-doc autotrace cups-bsd lpr lprng grads hp2xx html2ps libwmf-bin mplayer povray radiance texlive-base-bin transfig ufraw-batch
  inkscape
The following packages will be REMOVED:
  graphicsmagick-imagemagick-compat q4os-devpack
  imagemagick imagemagick-6.q16 imagemagick-common liblqr-1-0 libmagickcore-6.q16-2 libmagickcore-6.q16-2-extra libmagickwand-6.q16-2
  libnetpbm10 netpbm
0 upgraded, 9 newly installed, 2 to remove and 0 not upgraded.
Need to get 4,168 kB of archives.
After this operation, 12.4 MB of additional disk space will be used.
Do you want to continue? [Y/n]
I answered no at this point as I want to continue to use some of these packages marked for removal but I did notice that the packages that would be removed were graphicsmagick-imagemagick-compat and q4os-devpack, so would I be right in guessing that the standard imagamagick from the repo would remove the devpack and q4 imagamagick stuff?
My guess would be that I don't need to install imagemagick separately as I should have the package components via graphicsmagick-imagemagick-compat. Is that right?
#2 2016-05-04 10:57
Re: Installing imagemagick says I have software to be removed
There is a conflict between older version of 'q4os-devpack' and 'imagemagick' . If you want to install packages alongside, we would recommend to uninstall q4os-devpack, download and install the new version '2.2.2-a1' from Q4OS web and then install 'imagemagick' . This procedure should be ok, please let us know the result.
#3 2016-05-04 11:00
Thanks for the quick reply, I will try it out and post back the results. smile
#4 2016-05-04 11:13
Ok, I removed q4os-devpack but did not do autoremove on the other existing packages, then I installed the new q4os-devpack and then installed imagemagick and all went well. I do have a couple of packages listed as ready for autoremove though they are :-
graphicsmagick
libgraphicsmagick3
libqt4-assistant
libqt4-webkit
My guess would be it is ok to remove these as they are probably old packages, but will wait for confirmation before removing them.
#5 2016-05-04 11:15
Yes, they are no dependencies more, you can safely autoremove them.
#6 2016-05-04 11:43
Thank you, job done smile
