I have two discs on my computer. One has the win partition. The other has a linux partition and a partition with free space.I installed grub on sda but grub doesnt show up in the start screen. It just boots up straight to q4os. I tried update-grub2 and grub finds windows partition. But i still dont see a grub start screen. What did i do wrong here? Thanks in advance.
(sda1 = windows first disk,s db1 =second disk free space partition)
sorry deleted stupid my question
You may have set the timeout for grub too quick, you can edit the file /etc/default/grub and change the line that begins
GRUB_TIMEOUT= to be greater I'd say 10 should give you plenty of chance to see the menu.
You will also need to run
sudo update-grubto update the grub information.
The problem was the GRUB_TIMEOUT_STYLE= that had the value hidden by default. I looked up on google and it supposed to have the menu value to properly show grub. Changed it, rebooted and everything works fine. Thanks for your reply Dai_trying
You are welcome, I'm glad you got it sorted ![]()
