#1 2016-04-21 03:46
ThisGuy1996
Bourbon Menu
This new "Bourbon" menu is off the charts awesome! Any way to customize it?
#2 2016-04-21 06:15
Re: Bourbon Menu
Read http://www.q4os.org/dqa011.html#desktop.3
Use right mouse click and drag/drop operations to manage favorites. Some configuration options are shared with 'kickoff' menu in the '$HOME/.trinity/share/config/kickerrc' file.
#3 2016-04-28 10:26
leoz
Re: Bourbon Menu
Can't start  "Bourbon" menu
in the .trinity/share/config/kickerr file is no
'Bourbon' option
#4 2016-04-28 11:21
Re: Bourbon Menu
You can set Bourbon menu as a default from Welcome screen or from right mouse click on panel -> Configure Panel ... -> Menus
Bourbon options are included in 'kickerrc' from Q4OS 1.4.9 version.
#5 2016-10-04 11:59
Re: Bourbon Menu
How can I change font size in Bourbon menu? Changing TDE font size doesn`t help, Bourbon menu font size still 9.
Also how can I access Q4OS Welcome screen if it does not show at startup? Please write launching command, looks like I have deleted launching icon from Start menu.
#6 2016-10-04 12:38
Re: Bourbon Menu
... how can I access Q4OS Welcome screen if it does not show at startup? Please write launching command ...
$ welcome-screen.exu
You may find useful http://www.q4os.org/dqa011.html#desktop.5
Changing fonts for Bourbon menu works in general, but there is a glitch due to the font size 10 is rendered as 9. Other font sizes and types should be rendered correctly. It's added to our internal bug list.
You may also find useful http://www.q4os.org/dqa011.html#desktop.4
#7 2016-10-05 15:58
Re: Bourbon Menu
OK, understood, I will wait for fix then, because 9 font is too small but 11 is a bit big.
