Upon install the keyboard layout was set to English US. I added English UK and removed English US.
When I boot it reverts to US for the login screen and switches to UK after I sign in.
When I go into Regional settings only UK is listed as active as set. I can't understand why this persists for login only.
Running TDE R14.1.5
TDE's Regional settings only apply to your user session after you log in. The login screen uses the system-wide keyboard configuration, which is still set to US from the installation.
To change the login screen layout to UK, open a terminal and run:
sudo dpkg-reconfigure keyboard-configuration
Follow the prompts to select English (UK), then reboot. Alternatively, you can edit /etc/default/keyboard and set XKBLAYOUT="gb".
Thank you, this worked, I tried it last night and somehow it set to UK Colemark and I couldn't login - until I realised the layout wasn't what I thought.
Anyway, I got it sorted, thank you.
