Hello again,
thanks to the forum's support, last Sunday I was able to install Q4OS on my old Thinkpad T42. It went okay and I then kept thinkering with it (installing apps, customizing look, checking wireless connections, and testing light LibreOffice use, which would be my main use for this machine) for about four hours with absolutely no issue.
Starting from a couple of days ago tho, I've begun to experience sudden and weird freezes while using the OS. What happens is that the screen simply becomes unresponsive, the light indicator of SSD activity shuts off, and the laptop remains like that. Eventually, fans do kick in, but nothing changes. I haven't tried to wait for more than ten minutes to see if this eventually ends, I've simply turned the pc off and waited a bit before turning it on again.
If I immediately turn it on again, it seems to freeze on (or even before) startup, just a black screen even before the IBM logo shows up. If I wait just a couple of minutes it's all alright and it turns on like nothing ever happened.
My findings (and reasons I'm unsure what to do) so far: I cannot replicate these freezes. They just happen seemingly without a pattern, and I cannot even be sure the events I'm about to describe are part of the causes: it froze once after installing some fonts, once after opening LibreOffice, once while testing Abiword while checking CPU and RAM usage, once just after startup, without doing anything.
So I can't find a pattern: last Sunday I did all of those things without issues, for example.
Me being very ignorant in most tech related things doesn't help my understanding.
I've used the command
journalctl -b -1 -p err
after a few of those restarts to check issues on the previous sessions
but I'm not sure any of these can be a cause for such freezes? (altho I'd like to tackle them as well)
What I'd like to ask help with right now is figuring out what's happening, because I don't have enough knowledge to even begin to test for various causes, let alone solutions. I'm not even sure if this is an hardware issue, a software issue or both, nor how to check for each.
I know my machine is quite old and I can switch to another distro if it turns out to really have some massive incompatibilities with Q4OS, however I first have to know what exactly is happening in these freezes, and if and how they can be fixed/avoided, 'cause otherwise I just risk facing the same issues on a different OS.
inxi -F for reference
Thanks
That looks like failing hardware. First, we would recommend you to perform memory tests to rule out faulty RAM, as bad memory is a very common cause of random freezes.
Here is how to install and run the memory test in Q4OS:
1. Open a terminal and install memtest86+ by running:
$ sudo apt update && sudo apt install memtest86+
2. Once it finishes installing, reboot your laptop and watch the screen for the Q4OS boot menu. If the menu does not appear automatically, try holding the Shift key or tapping Esc right after the IBM logo disappears.
3. Use the arrow keys to select "Memory test (memtest86+)" and press Enter.
4. Let the test run until it completes at least one or two full passes—this may take a while depending on how much RAM you have.
Let us know how the memory test goes. Also, if you need us to check your journalctl or inxi outputs later, please save them to a file and attach here.
Okay, here's what happened: I installed memtest86+, rebooted and ran it.
It froze one minute in, and after turning the laptop off it wouldn't boot (got stuck at the IBM logo screen).
I waited a few minutes, then checked a RAM stick (pulled it out, inspected what I could visually, and then plugged it back in). It booted and I went into memtest86+ once again.
This time, it progressed for a while, about eight minutes, before freezing again at this screen
Could it be the RAM after all? How bad could it be to freeze this much?
The machine has two sticks of DDR1 RAM, 1GB each for a total of 2GB. Should I remove one and try to run memtest one stick at a time?
EDIT: I also have the original two 512MB sticks of RAM that came with the laptop and that I removed when upgrading it. Should I test those too to see if both of the 1GB stick are at fault or if it's the slots themselves?
Yes, freezing inside memtest86+ confirms that this is a hardware problem and not an issue with Q4OS.
Your plan is the right next step. Test the two 1GB sticks one at a time in the same slot to see if only one of them is faulty. Then, use your original 512MB sticks to test both the bottom slot and the slot under the keyboard to make sure the slots themselves haven't gone bad. Gently wiping the gold contacts on the sticks before inserting them can also help rule out a dirty connection.
Keep in mind that on the ThinkPad T42, freezing after warming up and refusing to boot until it cools down can also be caused by overheating or the well-known T42 GPU solder issue. Start with the RAM tests since that is easiest, and if it still freezes with the original 512MB sticks, let us know so we can check temperatures next.
Thanks for your patience.
I'll update with my findings as soon as possible.
Update: I think it was indeed a faulty ram stick that caused all the freezes.
Here's what I did in detail: I chose the slot under the keyboard and tested the 1GB sticks one at a time. The first immediately froze memtest, the second achieved multiple passes with no issue.
Then, I put the two 512MB stick back in, in both slots, and ran memtest again. Multiple passes again, no issue.
Without waiting, I rebooted the pc and went into the OS, doing the same things that happened during the past freezes: opening and closing docs, terminal checks, installing fonts, writing a bit with various formatting options. All of this with the two 512MB sticks inserted.
No freezes, no crashes.
I really think this was it, thanks a lot.
