Hello,
please bear with me as I am almost tech illiterate and very new to Linux in general, but I'm having an issue with installing Q4OS.
I have an old Thinkpad T42 (not a T420) that I've partially upgraded (maxed out RAM, hard disk to 256GB SSD swap), and it being a 32bit device I want to install Q4OS on it.
I made a bootable USB (with ventoy) and tried, but the installation freezed at exactly 83% of the very last step, right after saying "linux-image-686 (i386) package installed). It wasn't a simple stop or slow down, it really just froze and became unresponsive to any key.
(the language is Italian, sorry, but this should be the last step of installation, it says "Installing the base system" on top)
After a while (I think about 20 minutes) I simply aborted everything by turning the laptop off, and tried again. At my first new attempt to boot from the USB, this screen appeared.
Again, I turned it off and tried a third time. Everything went on smoothly like the first... until the 83% screen. Exactly the same. Same freeze at the exact same point and in the exact same way. This time I gave it around 40 minutes, to see if there was something just going veeeery slowly, but nothing happened. So, I aborted again.
I've currently installed antiX on this laptop, by booting it from the same USB, which essentially told me that both the computer and the USB seem to be fine.
But I'd like to really understand why Q4OS keeps freezing, as I really want to use that system instead and, to my (limited) knowledge, this whould all work.
Any help would be greatly appreciated, thanks.
In case it may be useful, these are the results of inxi -F (on antiX live, before installing):
Welcome to the forum
First, we recommend flashing the ISO to the USB using recommended tools https://www.q4os.org/dqa018.html#creat instead of Ventoy, as Ventoy often struggles with older BIOS systems.
Your ThinkPad T42 has an older Pentium M processor that hides or lacks the PAE flag required by the standard linux-image-686 kernel, which may cause the hard freeze at 83% while antiX works fine with its built-in non-PAE kernel. To fix this, boot the Q4OS USB, press Tab or e at the boot menu, and add forcepae to the end of the boot line before pressing Enter.
Thank you, I will try this method shortly.
One quick question before that, as I am not well versed in these technicalities: assuming adding forcepae is the correct fix for this issue, is it only required for the installation, and therefore once installed it will be no longer a concern of mine? Or will I have to do something else to ensure the processor doesn't have issues once the OS is up and running regularly?
First, try to burn the boot USB the recommended way https://www.q4os.org/dqa018.html#creat , install Q4OS from and post back. The "forcepae" injection is rather a test than fix.
Update: I prepared the boot USB the recommended way and tried an install. I did not add forcepae to the boot line during this attempt, as I wanted to test things one at a time.
It went beyond the previous 83% freeze, finished that whole process and progressed to software selection and installation, reaching 93% there
but it has been stuck on "extracting p7zip-full" for half an hour. I'm still waiting to see if it is just a very slow process or if there's been another freeze, but I guess it's still progress, and ventoy was at least partially responsible for the first seatback.
I'm thinking of waiting for maybe another 20 minutes before considering it completely frozen and going for another attempt. I'll keep updating.
Added later 2 h 49 min 39 s:
FINAL UPDATE: I did it, Q4OS is safely installed.
I want to briefly summarize my findings: that process was frozen at 93%, so I tried one more time after checking the boot USB. I suspect something went wrong when I first made it through Q4OS imager, as I remember a brief error flashing on screen. So, I just re-burned it, this time making sure the process went smoothly and without crashes or interruptions.
And, indeed, it worked.
So, in conclusion: no need for forcepae, it was all a matter of having the correct boot USB (no ventoy), correctly burned with the proper Q4OS imager (no errors or improper interruptions).
Thank you for the help!
Thanks for letting us know. +1
