#1 2026-11-12 17:58
Kachelkaiser
Login screen (SDDM) can't be chnaged
Hi
I am new to q4OS and I like the thin distrubution on a stable debian. I am running q4OS 6.10 on a DELL Latitude 7420
But I am facing one issue: I tried to change the Login Screen (SDDM) in the settings. Here I can select a different one and apply the setting. But after logout or reboot I only see a white screen containing a login field. The only login screen which works is the default one.
What can I do?
#2 2026-11-13 10:09
Re: Login screen (SDDM) can't be chnaged
Welcome to the forum smile
What SDDM theme do you want to switch to and what way exactly did you install the theme?
#3 2026-11-14 13:11
Kachelkaiser
I used the setting directly in KDE
I went to Login screen (sddm) and selected "Sugar Candy for SDDM" or "Sweet Mars" using the the "get new...." button
#4 2026-11-14 17:35
Hi Kachelkaiser,
That plain white screen is SDDM's built-in fallback screen, which appears whenever a selected theme fails to load.
Themes like Sugar Candy and Sweet Mars were written for older Plasma 5 (Qt5) setups, so they are incompatible with Q4OS 6 (Plasma 6 / Qt6). Additionally, KDE's "Get New..." installer only copies theme files and does not install missing system dependencies.
You can check the exact error in your terminal without logging out by running:
$ sddm-greeter-qt6 --test-mode --theme /usr/share/sddm/themes/sugar-candy
To fix this, look for an SDDM theme explicitly updated for Plasma 6 (such as Eucalyptus Drop, which is a Qt6-compatible fork of Sugar Candy). If a compatible theme still fails, check the terminal output from the command above and install any missing qml6 packages via apt.
