#1 2026-10-08 22:50
progrockfrog
Small gripe here, how can I fix this?
When I load Q4OS it loads wonderfully. But if I go on idle or to different areas the panel "contracts". See below
i.imgur.com/9DTbw7c.png
I can click on Firefox and it expands again to temporarily fix it. I don't see how I can tell it, "Stay fully expanded at all times."
#2 2026-10-09 10:38
Re: Small gripe here, how can I fix this?
This is the "floating panel" feature of Plasma 6. While no window touches the panel, it floats as a smaller rounded bar. When a window comes close or is maximized (for example Firefox), the panel snaps back to the screen edge at full size.
To keep the panel attached all the time, right-click an empty spot on the panel, choose "Show Panel Configuration", and switch "Floating" off.
#3 2026-10-09 10:45
progrockfrog
Thank you.
