#1 2026-10-01 15:43
AlbertoSalviaNovella
Consider Falkon
When I boot into Q4OS Trinity, I'm recommended to install Chrome to have modern web support.
Just wanted to let you know that Falkon supports the same, just with half the RAM.
So maybe it is a better default, at least to the lighter Trinity desktop.
Cheers!
https://es20490446e.wordpress.com
#2 2026-10-02 16:29
Taige
Re: Consider Falkon
Firefox is another good alternative along with Falkon, although the latter I think might be the right choice for older computers.
#3 2026-10-02 16:48
Re: Consider Falkon
My tests show that Falkon works without swapping with 4GB of RAM, Firefox with 6GB.
#4 2026-10-02 22:52
Re: Consider Falkon
Falkon seems faster/less ressource hungry than firefox. I'm questionning about website compatibility, I've seen some sites in the past that can't be rendered properly in falkon, maybe it's not the case now ? I'm curious about comparing it to thorium (chromium on steroids, very very optimized).
#5 2026-10-02 23:19
Re: Consider Falkon
I didn't see any flaw with Falkon.
If you want to properly test how much RAM a web browser really needs, just boot a virtual machine with that amount of RAM.
If you open a few YouTube tabs, and you see on the system monitor that swap is kicking in with no so trivial amounts, it means the amount of RAM isn't enough.
#6 2026-10-03 07:45
Taige
Re: Consider Falkon
Yes, Firefox requires more resources compared to Falkon because it has more advanced features and also has a different architecture.
So for simple navigation and or checking e-mail, Falkon is more suitable on computers with little ram and somewhat old processors, especially on laptops.
If there are no more problems of that type then it means that they will have fixed them, or at least I think so.
