#1 2016-04-09 08:04
Q4OS Orion 1.4.9 released
#2 2016-04-09 08:51
Re: Q4OS Orion 1.4.9 released
Can 'Bourbon' start menu be edited using "TDE menu editor?"
#3 2016-04-09 13:18
Bourbon menu uses the Q4OS menu structure in the initial configuration after installation. There are some incompatibilities with XDG specification, we are working on to fix it.
Nevertheless, it's easily possible to revert to the default TDE menu structure, see http://www.q4os.org/dqa011.html#desktop.2, and then to use TDE menu editor 'kmenuedit.tde2'
