#1 2026-08-31 15:23
radko
Remove old kernels, how?
How to uninstall older Linux kernels and dependencies to save space?
#2 2026-09-01 08:14
Re: Remove old kernels, how?
sudo apt search linux-image-* | grep installed
This is mine.
linux-headers-6.12.101+deb13-amd64/stable-security,now 6.12.101-1 amd64 [installed,auto-removable]
linux-headers-6.12.105+deb13-amd64/stable-security,now 6.12.105-1 amd64 [installed,automatic]
linux-headers-6.12.107+deb13-amd64/stable-security,now 6.12.107-1 amd64 [installed,automatic]
linux-headers-6.12.74+deb13+1-amd64/now 6.12.74-2 amd64 [installed,local]
linux-image-6.12.101+deb13-amd64/stable-security,now 6.12.101-1 amd64 [installed,auto-removable]
linux-image-6.12.105+deb13-amd64/stable-security,now 6.12.105-1 amd64 [installed,automatic]
linux-image-6.12.107+deb13-amd64/stable-security,now 6.12.107-1 amd64 [installed,automatic]
linux-image-6.12.48+deb13-amd64/now 6.12.48-1 amd64 [installed,local]
linux-image-6.12.74+deb13+1-amd64/now 6.12.74-2 amd64 [installed,local]
linux-image-amd64/stable-security,now 6.12.107-1 amd64 [installed]
I then just step through the list one by one using sudo apt remove to just leave 2 kernels followed by sudo apt autoremove to clear any kbuild and header files
sudo apt remove linux-image-6.12.101+deb13-amd64
The following packages were automatically installed and are no longer required:
  linux-headers-6.12.101+deb13-common   linux-kbuild-6.12.101+deb13
  linux-headers-6.12.74+deb13+1-common  linux-kbuild-6.12.74+deb13+1
Use 'sudo apt autoremove' to remove them.
REMOVING:
  linux-headers-6.12.101+deb13-amd64  linux-image-6.12.101+deb13-amd64
If you have Synaptic installed you can just use that and pick all the ones you want to remove in one go.
#3 2026-09-01 16:07
radko
Thanks a lot
For me working solution is Synaptic.
#4 2026-09-19 17:06
Anything wrong with this?  neutral
$ sudo apt-get autoremove
#5 2026-09-20 07:31
Taige
Does removing old kernels have the advantage of saving disk space, or does it also affect performance?
#6 2026-09-20 08:17
Taige wrote:
... or does it also affect performance?
No performance impact.
#7 2026-09-20 10:15
Taige
Some time ago I read that an ssd that is not full can help keep it in excellent health because a drive with free space certainly reduces wear and tear and this consequently improves its performance.
I think that the removal of old kernels also has a positive impact on this aspect even if it does so indirectly.
If the reasoning is wrong, explain to me how it is, I'm trying to understand.
