#1 2026-09-19 23:27
Sunset17
Is there something unique about LibreWriter in Q4OS?
New to Q4OS, I have used LibreOffice in all the Linux distros I've used. This is the first time it is not opening a file (.odt) and displaying properly. The settings seem to be correct, yet the text does not fit the page as it should. Is there a setting in display configuration that could affect this? This is my first distro based only on debian. Last several were based on ubuntu. Does that affect the apps that are installed?
#2 2026-09-20 06:49
Re: Is there something unique about LibreWriter in Q4OS?
Hello and welcome to Q4OS
In short, no there is nothing in Debian that would cause this on its own.
Without seeing a screenshot of the issue it's a bit difficult and we'll need to wait for the devs to allow you to upload images.
However, the first thoughts would be fonts and page sizes. If the fonts used ate not present then you'll get substitution that may cause layout issues
It's worth checking in your Q4OS settings to make sure you have your locale / country set correctly to make sure the correct page sizes are there.
If you open the file and then save as a doc or docx is the resulting file also not correct when you open that?
#3 2026-09-20 07:28
Taige
This happens when you switch from Ubuntu-based distributions to one that is directly based on Debian -> Q4OS.
The problem that manifests itself with  that .odt file is most likely due to the lack of the correct font and perhaps also due to the way the program itself is displayed.
To solve it, it should be sufficient to install the essential fonts package.  wink
#4 2026-09-21 00:43
Sunset17
Thank you bin. I checked locale/country everything is set correctly. I saved as docx but it didn't help. Even though it showed the correct font in the menu area, when I scrolled through the fonts it isn't there. I scrolled through the available fonts trying several, but nothing came close to the formatting I have used. I was surprised there aren't that many fonts, just many language variations of a few.  I appreciate your input.
Added later 11 min 04 s:
Thank you Taige. I appreciate the help. That does appear to be the problem, not having the font I had used. I should have thought of that, it was a common occurance in my working days with windoz. I searched in several locations and I'm not finding an "essential fonts package". Could you direct me to where I could find it?
#5 2026-09-21 07:30
The best solution is to list the names of the missing fonts for your document, search the web for them (you need likely .ttf files) and install them on your system. A lot of fonts are free and available for free. The way to install them depends on your desktop environment (System settings > Fonts > ... on Plasma). If the original fonts on your previous system are free of right, you can even copy them (the .ttf files) on an USB key and install it on Q4OS.
Another possibility is to configure LibreOffice to let it know which font to use in the case a font in your document is missing. From LO menu use Tools > Options > LibreOffice > Fonts and fill the Replacement or Substitution table. Also check the box under the list to apply the substitutions.
#6 2026-09-21 08:07
Taige
I think hchiper's solution might help you fix the problem.
Or you could change the font in the original document and choose one that is present in the target operating system.
#7 2026-09-21 08:35
No, Q4OS features the stock Debian Libreoffice.
#8 2026-10-06 01:55
Sunset17
Update: Many rabbit holes later...the font was present in the usr font folder, that's why it was still showing it in Writer. The version of LibreOffice that came with Q4OS is different and is actually in the not updated section on LibreOffice site  [Index of /libreoffice/old/25.2.3.2]. I removed it and installed a current flatpak version. Didn't help. I tried changing margins, didn't help. File type didn't matter. I tried several different fonts, too much of the formatting was affected, so I scrapped that. I tried multiple screen display settings, nothing helped. The one thing I did not try was loading some different english fonts, I would have if changing the font size hadn't had much effect, but that is what I resorted to. It was already small, so NOT ideal, but there is a lot of formatting that I didn't need to change at least. So, it was a resolution, but not perfect.
Other than the LibreOffice issue, I really like Q4OS. Printer works. Touchscreen laptop working great (it's an old Pentium Silver!). Logitech mouse works. So, it's time to install on the PC.
Even though no suggestions worked, I really appreciate the attemps to help.
#9 2026-10-06 11:46
Thanks for the update. A few facts that may help pin it down:
Q4OS doesn't change anything about LibreOffice or its page layout. LibreOffice is the stock Debian build, and when you install it with Desktop Profiler or Software Centre it brings the same font set Debian recommends (Liberation, DejaVu, Carlito, Caladea, Linux Libertine, Gentium, Noto). The fact that the flatpak behaves the same confirms the issue is the font, not LibreOffice: both use the same system fonts.
The clue is in your earlier post: the font name is shown in Writer's font box, but it isn't in the dropdown list. That means the font isn't found and LibreOffice substitutes another one with different letter widths, so the text reflows. A file sitting in /usr/share/fonts is not enough; it has to be readable for your user and recognised by fontconfig. Please run in a terminal (replace the name with the font your document uses):
$ fc-list | grep -i "Font Name"
$ fc-match "Font Name"
If the first prints nothing, or the second returns a different family (e.g. DejaVu Sans), the font isn't seen.
Common reasons:
The file was copied as root and is not world-readable. Fix:
$ sudo chmod -R a+rX /usr/share/fonts && sudo fc-cache -f
Alternatively put the .ttf files into ~/.local/share/fonts (no root needed) and run
$ fc-cache -f
The document uses Microsoft fonts (Calibri, Cambria, Arial, Times New Roman, Georgia, Verdana...). Some Ubuntu-based distros install those for you; on Q4OS run:
$ sudo apt install ttf-mscorefonts-installer
Calibri and Cambria have metric-compatible clones (Carlito, Caladea) that already come with LibreOffice. Only the Regular style is installed; missing Bold/Italic files make LibreOffice synthesise them with different widths. Install the complete family. The name inside the font file differs from the name the document uses. Check with:
$ fc-scan --format '%{family}\n' /path/to/font.ttf
If you post the font name and the output of fc-match, we can tell you exactly which case it is.
