Good morning,
my system:
- s.o: "Q4OS Aquarius, Trinity - 32bit / i386"
- pc: Acer travel Mate 4652 with Intel pentium M740
The browser Firefox Esr is it very slow: both at startup and in use.
It's normal for this pc, or recommend another browser.
Thanks.
Firefox can indeed be slow on your hardware, especially on modern JavaScript-heavy websites. Startup time can also be relatively long. You could try a lighter browser, for ex. Falcon, but don't expect a dramatic improvement on today's web. The main limitation is the CPU and the amount of work modern web pages require, rather than Q4OS itself. For such old hardware, we would also recommend keeping the number of simultaneously open tabs low and avoiding heavy websites where possible.
If you post the output of:
$ free -h
$ inxi -Fxz
we can have a better look at whether there is a hardware/resource limitation.
$ free -h
with only Firefox active and sigle card.
~$ free -h
total used free shared buff/cache available
Mem: 2,0Gi 869Mi 682Mi 71Mi 732Mi 1,1Gi
Swap: 0B 0B 0B$ inxi -Fxz
inxi -Fxz
System:
Kernel: 6.1.0-52-686-pae arch: i686 bits: 32 compiler: gcc v: 12.2.0
Desktop: Trinity v: R14.1.1 Distro: Q4OS 5.10-deb12u1 base: Debian
GNU/Linux 12 (bookworm)
Machine:
Type: Laptop System: Acer product: TravelMate 4650 v: N/A
serial: <superuser required>
Mobo: Acer model: Dunlin v: * serial: <superuser required> BIOS: Acer
v: 1.80D date: 05/25/2005
Battery:
ID-1: BAT1 charge: 47.0 Wh (100.0%) condition: 47.0/63.6 Wh (73.9%)
volts: 16.5 min: 14.8 model: SONY BATCL50L status: full
CPU:
Info: single core model: Intel Pentium M bits: 32 arch: M Dothan rev: 8
cache: 2 MiB note: check
Speed (MHz): 800 min/max: 800/1733 core: 1: 800 bogomips: 3457
Flags: nx pae sse sse2
Graphics:
Device-1: Intel Mobile 915GM/GMS/910GML Express Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-3
bus-ID: 00:02.0
Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: intel
unloaded: fbdev,modesetting,vesa dri: i915 gpu: i915
resolution: 1400x1050~60Hz
API: OpenGL v: 2.1 Mesa 22.3.6 renderer: i915 (: 915GM) direct-render: Yes
Audio:
Device-1: Intel 82801FB/FBM/FR/FW/FRW AC97 Audio
vendor: Acer Incorporated ALI driver: snd_intel8x0 v: kernel bus-ID: 00:1e.2
API: ALSA v: k6.1.0-52-686-pae status: kernel-api
Network:
Device-1: Broadcom NetXtreme BCM5788 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: tg3 v: kernel port: N/A
bus-ID: 05:01.0
IF: enp5s1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel PRO/Wireless 2200BG [Calexico2] Network driver: ipw2200
v: 1.2.2kmprq bus-ID: 05:02.0
IF: wlp5s2 state: down mac: <filter>
Drives:
Local Storage: total: 55.89 GiB used: 4.12 GiB (7.4%)
ID-1: /dev/sda vendor: Western Digital inxi -Fxz
System:
Machine:
Battery:
CPU:
Graphics:
bus-ID: 00:02.0
Audio:
Network:
bus-ID: 05:01.0
Drives:
ID-1: /dev/sda vendor: Western Digital model: WD600UE-22HCT0
Partition:
ID-1: / size: 19.71 GiB used: 4.12 GiB (20.9%) fs: ext4 dev: /dev/sda3
Swap:
Alert: No swap data was found.
Sensors:
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Info:
Processes: 141 Uptime: 10m Memory: 1.96 GiB used: 902.4 MiB (45.1%)
Init: systemd target: graphical (5) Compilers: N/A Packages: 1204
Shell: Bash v: 5.2.15 inxi: 3.3.26
Partition:
Swap:
Sensors:
or lm-sensors.
Info:
Shell: Bash v: 5.2.15 inxi: 3.3.26@EDIT
Which way to I install Falkon:
https://www.falkon.org/download/
Hello,
I installed Falkon browser, as suggested, by Synaptic.
But, when it start the research to crash.
How suggested in another post, I actived Falkon in the terminal: the message appared
"segmentation fault".
I tried to start Falkon browser with new user but it goes wrong anyway.
@EDIT
That page offers various methods for installing Falkon, but you haven't specified which one you used.
You could try uninstalling it, then installing it from the Q4OS Software Centre, and see what happens.
Hello,
How do I become a root user?
I have to modify the file sources.list and delete icons from my desktop:
it is necessary to be user root.
Thanks.
p.s.
The best way is to use "sudo" command. You can also run file manager as root > main menu > applications > system > superuser > file manager.
If you want remove icons from desktop you don't need to be root, just select the icon and pres "del" key.
In the installation Falkon with file
org.kde.falkon.flatpakref
F: Transaction: install flathub:app/org.kde.falkon/i386/stable[]
error: No such ref 'app/org.kde.falkon/i386/stable' in remote flathub
package installation ....failed
Unfortunately, Flathub features no 32bit flatpak packages.
Does the laptop have 512mb or 2gb of ram?
It seems, Falkon fails on your hardware due to some hw incompatibility or bug. In anyway, it's hardware dependent as we are not able to reproduce on our testing machine, Falkon works fine here.
You could also try even more lightweight alternative Dillo:
$ sudo apt install dillo
