#1 2026-09-15 03:10
not_a_rockstar
Intel X5-Intel X5-Z8300 Atom Quad is 6t4 bit but needs a 32 bit UEFI
I've found looking around on other forums that a 32 bit file is needed for this particular processor for proper Linux boot.  Presently it gets almost nowhere.
Here's what Google AI says, and it makes sense to me:
The Intel Atom x5-Z8300 processor has a 64-bit architecture, but almost every computer built with it uses a restricted 32-bit UEFI firmware. [1] This mismatch means a standard 64-bit Linux USB installer will refuse to boot on your PC. You need a setup specifically configured to bridge this 32-bit to 64-bit gap.
There are instructions as to how to add a file to the EFI | boot directory of a rufus generated installer USB stick.
Add the Boot File: Before unplugging the USB drive, open it in your file manager. Go into the EFI folder, then open the BOOT folder. Download a file named bootia32.efi (available on open-source repositories like GitHub) and drop it directly into that BOOT folder. [1]
But it appears that someone posted in the forums 3 years ago, that this type of early Atom processor that uses 32bit UEFI simply cannot use Q4OS.  is that actually the case?
#2 2026-09-15 11:18
Re: Intel X5-Intel X5-Z8300 Atom Quad is 6t4 bit but needs a 32 bit UEFI
We would recommend you to use "install-cd" to install Q4OS and post back the result.
#3 2026-09-15 17:15
not_a_rockstar
I tried using the install CD image - using rufus to make a bootable USB stick - same result.  I do have a USB CD Drive - should I try to make a bootable CD and try to boot from that?
#4 2026-09-15 18:34
No, it wouldn't make things better. Q4OS media feature 64bit UEFI binaries only.
You could also try to install plain Debian and Q4OS on top of that Debian setup according to https://www.q4os.org/dqa017.html . Please report the result.
#5 2026-09-15 22:20
not_a_rockstar
OK, I'm going to see if there's a Debian distro that does this 32bit UEFI bridging, then follow the Q4OS installation instructions.  I'm very green at linux - have only done recent fedora installs on a couple of machines that M$ says are no good for Win11.  That was really stretching my abilities!
Oddly enough, I have some UNIX experience from the late 1980's.  Console stuff for linux was sort of a throwback to those days.
Added later 33 min 09 s:
Debian installers seem to want to use either a net installation (with a live internet connection - which I don't have on this machine) or via a CD or DVD image burned to either of those.  I wonder if I'm using too large of a USB stick - it's a USB 3.0, 126 GB stick.  I'm going to try a smaller USB stick with a DVD image burned to it.
Added later 21 h 25 min 16 s:
I was unable to install Debian - and could only run portions of the Grub live version - due to a bin and related txt file specific to the machine - which is a MINIX Z83/4.  I found two of these little boxes.  They have a TF card slot, and I might actually try inserting a higher capacity microSD into the slot and installing Debian/Q4OS to that - but I'm running out of steam.
