#1 2026-09-12 23:02
ChillKid
Konqueror Bugs When Opening ZIP files
Hello, so I recently downloaded some zip files and when I try to open them in Konqueror, it opens like 2 blank konqueror windows per second and it loops this forever, which forces me to restart my computer. Kind of like the "you are an idiot" popups
?u=https%3A%2F%2Fi.ytimg.com%2Fvi%2F8kgs_ogh46I%2Fmaxresdefault.jpg&f=1&nofb=1&ipt=f8f8301fd8662a8fa32b3f38eabd36eff7ffea616b6ebdc02e70d33b85339a06
If anyone has any ideas to what could be causing it, it would be highly appreciated. Thank you
inxi -F output:
System:
  Host: DellLatitudeE6420 Kernel: 6.12.101+deb13-amd64 arch: x86_64 bits: 64
  Desktop: TDE (Trinity) v: R14.1.5 Distro: Q4OS 6.8-deb13u1
Machine:
  Type: Laptop System: Dell product: Latitude E6420 v: 01
    serial: <superuser required>
  Mobo: Dell model: 0P6K8J v: A00 serial: <superuser required> BIOS: Dell
    v: A25 date: 03/06/2018
Battery:
  ID-1: BAT0 charge: 44.3 Wh (99.6%) condition: 44.5/48.8 Wh (91.1%)
CPU:
  Info: dual core model: Intel Core i5-2520M bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 1619 min/max: 800/3200 cores: 1: 1619 2: 1619 3: 1619
    4: 1619
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    driver: i915 v: kernel
  Device-2: Sunplus Innovation Laptop_Integrated_Webcam_FHD driver: uvcvideo
    type: USB
  Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: crocus gpu: i915 resolution: 1366x768~60Hz
  API: EGL v: 1.5 drivers: crocus,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 25.0.7-2+deb13u1
    renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
  API: Vulkan v: 1.4.309 drivers: llvmpipe surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
    driver: snd_hda_intel
  API: ALSA v: k6.12.101+deb13-amd64 status: kernel-api
  Server-1: aRts v: 1.5.10 status: active
  Server-2: PipeWire v: 1.4.2 status: active
Network:
  Device-1: Intel 82579LM Gigabit Network driver: e1000e
  IF: eno1 state: down mac: d4:be:d9:30:bb:0c
  Device-2: Broadcom BCM43228 802.11a/b/g/n driver: bcma-pci-bridge
  IF-ID-1: wlp2s0b1 state: up mac: e0:06:e6:02:25:98
RAID:
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
Drives:
  Local Storage: total: 119.24 GiB used: 16.46 GiB (13.8%)
  ID-1: /dev/sda vendor: Samsung model: MZ7TY128HDHP-000H1 size: 119.24 GiB
Partition:
  ID-1: / size: 108.15 GiB used: 16.46 GiB (15.2%) fs: ext4 dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 54.0 C mobo: 30.0 C sodimm: 40.0 C
  Fan Speeds (rpm): cpu: 0
Info:
  Memory: total: 8 GiB available: 7.65 GiB used: 1.6 GiB (20.9%)
  Processes: 195 Uptime: 3h 4m Shell: Bash inxi: 3.3.38
#2 2026-09-13 14:09
Re: Konqueror Bugs When Opening ZIP files
This looks like a broken MIME association, possibly with ZIP files being associated with Konqueror itself, which could explain the endless spawning of new windows.
Please try the following from a terminal, replacing the path with an actual ZIP file:
$ xdg-mime query filetype /path/to/file.zip
$ xdg-mime query default application/zip
Also try launching the ZIP directly from a terminal:
$ konqueror /path/to/file.zip
If it starts spawning windows again, please post the messages printed in the terminal. That should give us a good indication of what is causing the loop. You can also post the output of:
$ kreadconfig --file ~/.config/mimeapps.list --group "Default Applications" --key application/zip
Normally ZIP files should be handled by an archive manager such as Ark, not by Konqueror itself.
