#1 2026-07-28 10:25
Pado
br-connection refused
HELLO,
After latest upgrade, I can't connect my bluetooth speaker anymore.
I get this message : br-connection refused
Any idea on what's going on and how to solve the problem ?
Thank you for your answers
#2 2026-07-28 10:58
Re: br-connection refused
We are not able to confirm any upgrade, what would break bluetooth. Please follow tips by AI below and post back the result.
Generated by AI:
> **"br-connection refused"** usually indicates that the Bluetooth pairing information has become invalid after an update. First, remove the speaker from **Bluetooth Devices**, put the speaker into pairing mode, and pair it again.
> If that doesn't help, try removing the stored pairing information:
> ```bash
> bluetoothctl
> paired-devices
> remove <MAC-address-of-speaker>
> quit
> Then restart the Bluetooth service:
> ```bash
> sudo systemctl restart bluetooth
> and pair the speaker again.
> If the issue persists, please provide:
> * your Q4OS version (`cat /etc/q4os_version`)
> * the output of:
>   ```bash
>   bluetoothctl show
>   bluetoothctl info <MAC-address>
>   journalctl -u bluetooth -b
> * the model of your Bluetooth adapter and speaker.
> This will help determine whether the problem is related to BlueZ, the kernel, or the recent system update.
This is a common symptom after BlueZ or kernel updates, where re-pairing the device resolves the problem. If not, the Bluetooth logs are usually needed to identify the underlying cause.
#3 2026-07-28 17:38
Pado
removing and pairing again worked. Thank you.
#4 2026-07-28 17:43
