#1 2026-07-25 20:50
Digidoc
Upgrade Command
I run Q4OS on my laptop. It does not get much use, as my vision is no longer sharp. I think it is a few versions behind, perhaps 6.5 (or so). I run Spotify for music and Brave for browsing. Sometimes I transfer a few media files on USB.
Is there a single command to use to upgrade everything to the latest 6.8? Should I consider doing this or should I leave it alone?
#2 2026-07-25 22:48
Re: Upgrade Command
Open a terminal and run `sudo apt update && sudo apt full-upgrade` or install Update Manager from the Software Centre (it will check for upgrades each day and ask to install them if any is available).
