Hello everyone,
I am reaching out because I have an update that
isn't installing, and I can't figure out why since
there is no error message.
KDE Application Platform
The update to version 6.10 fails; it loops infinitely.
I am using linux version q4os-6.7-x64
Regards
[Resolved]
Are you updating through Discover, Flatpak, or the command line or some other tool ?
What exactly is the package name shown in the updater ?
The update is performed via Discover
and the package name is:
The update to version 6.10 369.2 MiB
Could you open a terminal and post the output of:
$ sudo apt update
$ sudo apt full-upgrade
$ flatpak update
$ flatpak list | grep "KDE"
Do other updates install normally in Discover.?
totone@tp-atzz:~$ sudo apt update
Reached: 1 http://deb.debian.org/debian trixie InRelease
Reached: 2 http://deb.debian.org/debian trixie-updates InRelease
Reached: 3 http://security.debian.org trixie-security InRelease
Reached: 6 https://dl.winehq.org/wine-builds/debian trixie InRelease
Reached: 7 https://liquorix.net/debian trixie InRelease
Reached: 8 https://q4os.sourceforge.io/qexarepo/s4-snapshot trixie-s4-snapshot-cn InRelease
Reached: 9 https://packages.mozilla.org/apt mozilla InRelease
Reached: 4 https://q4os.org/q4repo q4os-6-0-cn InRelease
Reached: 5 https://q4os.org/qexarepo/firefox trixie-firefox-cn InRelease
2 packages can be upgraded. Run "apt list --upgradable" to see them.
totone@tp-atzz:~$ sudo apt full-upgrade
Updated:
firefox firefox-l10n-fr
Summary:
Upgraded: 2. Installed: 0. Removed: 0. Not upgraded: 0
Download size: 87.5 MB
Required space: 376 kB / 82.2 GB available
Continue? [Y/n] y
Fetching: 1 https://packages.mozilla.org/apt mozilla/main all firefox-l10n-fr all 152.0.1~build1 [445 kB]
Fetching: 2 https://packages.mozilla.org/apt mozilla/main amd64 firefox amd64 152.0.1~build1 [87.1 MB]
87.5 MB fetched in 14s (6170 kB/s)
(Reading database... 310180 files and directories currently installed.)
Preparing to unpack .../firefox-l10n-fr_152.0.1~build1_all.deb ...
Unpacking firefox-l10n-fr (152.0.1~build1) over (152.0~build1) ...
Preparing Unpacking .../firefox_152.0.1~build1_amd64.deb ...
Unpacking firefox (152.0.1~build1) onto (152.0~build1) ...
Setting up firefox (152.0.1~build1) ...
Setting up firefox-l10n-fr (152.0.1~build1) ...
Processing triggers for hicolor-icon-theme (0.1
8-2) ...
Processing triggers for man-db (2.13.1-1) ...
Processing triggers for desktop-file-utils (0.2
8-1) ...
totone@tp-atzz:~$ flatpak update
Looking for updates…
Info: runtime org.kde.Platform branch 5.15-24.08 is end-of-life, with reason:
We strongly recommend moving to the latest stable version of the Platform and SDK
Info: applications using this runtime:
info.smplayer.SMPlayer
ID Branch Op Remote Download
1. [✓] org.kde.Platform.Locale 6.10 u flathub 1.0 KB / 401.3 MB
2. [✓] org.kde.Platform 6.10 u flathub 1.1 KB / 387.1 MB
Full updates.
totone@tp-atzz:~$ flatpak list | grep "KDE"
KDE Application Platform org.kde.Platform 5.15-24.08 system
KDE Application Platform org.kde.Platform 5.15-25.08 system
KDE Application Platform org.kde.Platform 6.10 system
totone@tp-atzz:~$
The other installations are properly set up with Discover.
Try to clear local cached obsolete data and post back the result.
$ sudo flatpak repair
$ flatpak uninstall --unused
$ flatpak update
Reboot
To clear the caches, I use BleachBit
sudo flatpak repair
[9/87] Verifying flathub:runtime/com.adobe.Flash_Player_Projector.Locale/x86[12/87] Verifying flathub:runtime/org.freedesktop.Platform.Locale/x86_64/24.[20/87] Verifying flathub:runtime/io.gitlab.librewolf_community.Locale/x86_6[22/87] Verifying flathub:app/com.adobe.Flash-Player-Projector/x86_64/stable[24/87] Verifying flathub:runtime/org.libreoffice.LibreOffice.Locale/x86_64/[29/87] Verifying flathub:runtime/org.freedesktop.Platform.codecs-extra/x86_[32/87] Verifying flathub:runtime/org.freedesktop.Platform.GL.default/x86_64[34/87] Verifying flathub:app/io.github.thetumultuousunicornofdarkness.cpu-x[36/87] Verifying flathub:runtime/io.github.linx_systems.ClamUI.Locale/x86_6[40/87] Verifying flathub:runtime/io.github.thetumultuousunicornofdarkness.c[42/87] Verifying flathub:runtime/org.filezillaproject.Filezilla.Locale/x86_[55/87] Verifying flathub:runtime/io.github.amit9838.mousam.Locale/x86_64/st[60/87] Verifying flathub:runtime/org.freedesktop.Platform.GL.default/x86_64[65/87] Verifying flathub:runtime/org.freedesktop.Platform.GL.default/x86_64[70/87] Verifying flathub:runtime/org.freedesktop.Platform.Locale/x86_64/25.[77/87] Verifying flathub:app/org.torproject.torbrowser-launcher/x86_64/stab[81/87] Verifying flathub:runtime/org.freedesktop.Platform.openh264/x86_64/2[87/87] Verifying flathub:runtime/org.freedesktop.Platform.GL.default/x86_64/25.08…
Checking remotes...
Pruning objects
Erasing .removed
Nothing unused to uninstall
flatpak update
Note that the directories
'/var/lib/flatpak/exports/share'
'/root/.local/share/flatpak/exports/share'
are not in the search path set by the XDG_DATA_DIRS environment variable,
so applications installed by Flatpak may not appear on your desktop until
the session is restarted.
1. [✓] org.kde.KStyle.Adwaita 5.15-24.08 i flathub 6,7 Mo / 6,7 Mo
2. [✓] org.kde.KStyle.Adwaita 5.15-25.08 i flathub 6,6 Mo / 6,6 Mo
3. [✓] org.kde.KStyle.Adwaita 6.10 i flathub 8,6 Mo / 8,6 Mo
4. [✓] org.kde.Platform.Locale 6.10 u flathub 1,0 Ko / 401,3 Mo
5. [✓] org.kde.Platform 6.10 u flathub 1,1 Ko / 387,1 Mo
Changes complete.
After completing the requested commands,
the problem persists: the update is not performing.
I briefly saw this at startup:
Error Kmod_config_parse
But no error appears in dmesg
Hello everyone,
I think I've solved the problem attributed to
KDE Application Platform version 6.10 failing to install
After some online research, seeing that other distributions
had similar issues,it turns out that Tor Browser was blocking
the KDE Application Platform version 6.10 installation with
a request in a loop.
Here's the message: "Can't remove org.kde.Platform/x86_64/6.10,
it is needed for: org.torproject.torbrowser-launcher"
Once Tor Browser was uninstalled, this installation disappeared,
and other updates that I thought were blocked were installed.
Will this help anyone?
Regards
Thanks for sharing the solution ![]()
