#1 2026-06-13 05:15
radko
How to shut down system at specific time?
#2 2026-06-13 06:46
Re: How to shut down system at specific time?
One solution is to use cron
This web page explains it all very well https://www.centron.de/en/tutorial/linu … with-cron/
Go down to the section Advanced Scheduling of the Shutdown Command for the details you need but basically it is:-
$ sudo crontab -e
no crontab for root - using an empty one
Select an editor.  To change later, run 'select-editor'.
  1. /bin/nano        <---- easiest
  2. /usr/bin/vim.basic
  3. /usr/bin/vim.tiny
  4. /bin/ed
Choose 1-4 [1]: 1
Make a selection and continue.
Note: Using sudo to edit the crontab means the command will run as the root user.
Next, add the following line:
0 23 * * * /usr/sbin/shutdown -h +30 "The system will shutdown in 30 minutes."
Save and exit the editor.
 Ctrl O to save then Ctrl X to exit
This Cron Job schedules the system to power off every day at 23:30 with a 30 minute warning at 23:00. Adapt to the timings you require.
