the only lingua is En, than now lxqt is my DE, which is fine.
As in TDE, the CD apps seemed conveinent: it shows the name of the songs automaticly. Now lxqt DE, it just shows the songs with No. 1, 2,3, etc.
What is the good app of TDE that makes CD better to manage? Could I install it in lxqt De?
In TDE, I can only select English
You can select plenty of languages in TDE. What language do you want to install ? Did you select language upon Q4OS installation ?
You can try Amarok-trinity.
Since I am a rookie, and lxqt De works fine, I shall not try and mess myself. Thanks.
I can select the lingua during installing, after installed, other lingua cannot be select.
Please post some error messages and detailed description. A screenshot would be valuable too.
hum.....fist of all, where's the photo when I pressed print screen? Unlike other De,it is.
Than after I reinstalled a few time, I found the key: during installation with Internet connected,the language will be OK. On the other hand, no Internet and installed, than Internet connected, reboot, never can be installed the desired lingua again. You might have tried and see.
Since it's been resolved, another issue appears : musescore3 can't be installed while most De can.
2 can but 3 can't. I successfully use 3 in q4os lxqt De, but tde, as it's
original can't.
You should give more detailed information:
- how did you try to install muscescore3?
- what makes you think it cant' be installed?
- copy/paste the error message if you got any.
Normally, `sudo apt install musescore3` should work.
.. during installation with Internet connected,the language will be OK. On the other hand, no Internet and installed, than Internet connected, reboot, never can be installed the desired lingua again. You might have tried and see.
It works fine here. Just select language upon install, proceed installation, reboot, login and "Install language" icon appears on the desktop. Click it and install the language. Does it work for you ? Please describe in more detail
.. another issue appears : musescore3 can't be installed while most De can
You can easily install from O4OS software center or follow @hchiper advice above. It works fine here. How do you try to install Musescore ?
- copy/paste the error message if you got any.Normally, `sudo apt install musescore3` should work.
Yes, please follow @hchiper advice too and post the info..
You can take screenshots with your phone or with "Ksnapshot" tool from main menu.
now I can. Before that, in syntactic, I looked for musescore, the 3 didn't appear, I made a new USB installer to reinstall,3 can be here.
the first issue might be the result of slower Internet connect.
