#1 2026-06-06 13:54
Updating Q4OS (Gemini) to the latest kernel
Hello,
with an  apt-cache search linux-image | grep 5.  i get the following large list:
~\> apt-cache search linux-image | grep 5.
linux-headers-5.10.0-30-amd64 - Header files for Linux 5.10.0-30-amd64
linux-headers-5.10.0-30-cloud-amd64 - Header files for Linux 5.10.0-30-cloud-amd64
linux-headers-5.10.0-30-rt-amd64 - Header files for Linux 5.10.0-30-rt-amd64
linux-headers-5.10.0-32-amd64 - Header files for Linux 5.10.0-32-amd64
linux-headers-5.10.0-32-cloud-amd64 - Header files for Linux 5.10.0-32-cloud-amd64
linux-headers-5.10.0-32-rt-amd64 - Header files for Linux 5.10.0-32-rt-amd64
linux-image-5.10.0-30-amd64-dbg - Debug symbols for linux-image-5.10.0-30-amd64
linux-image-5.10.0-30-amd64-unsigned - Linux 5.10 for 64-bit PCs
linux-image-5.10.0-30-cloud-amd64-dbg - Debug symbols for linux-image-5.10.0-30-cloud-amd64
linux-image-5.10.0-30-cloud-amd64-unsigned - Linux 5.10 for x86-64 cloud
linux-image-5.10.0-30-rt-amd64-dbg - Debug symbols for linux-image-5.10.0-30-rt-amd64
linux-image-5.10.0-30-rt-amd64-unsigned - Linux 5.10 for 64-bit PCs, PREEMPT_RT
linux-image-5.10.0-32-amd64-dbg - Debug symbols for linux-image-5.10.0-32-amd64
linux-image-5.10.0-32-amd64-unsigned - Linux 5.10 for 64-bit PCs
linux-image-5.10.0-32-cloud-amd64-dbg - Debug symbols for linux-image-5.10.0-32-cloud-amd64
linux-image-5.10.0-32-cloud-amd64-unsigned - Linux 5.10 for x86-64 cloud
linux-image-5.10.0-32-rt-amd64-dbg - Debug symbols for linux-image-5.10.0-32-rt-amd64
linux-image-5.10.0-32-rt-amd64-unsigned - Linux 5.10 for 64-bit PCs, PREEMPT_RT
linux-image-5.10.0-30-amd64 - Linux 5.10 for 64-bit PCs (signed)
linux-image-5.10.0-30-cloud-amd64 - Linux 5.10 for x86-64 cloud (signed)
linux-image-5.10.0-30-rt-amd64 - Linux 5.10 for 64-bit PCs, PREEMPT_RT (signed)
linux-image-5.10.0-32-amd64 - Linux 5.10 for 64-bit PCs (signed)
linux-image-5.10.0-32-cloud-amd64 - Linux 5.10 for x86-64 cloud (signed)
linux-image-5.10.0-32-rt-amd64 - Linux 5.10 for 64-bit PCs, PREEMPT_RT (signed)
linux-headers-5.10.0-43-amd64 - Header files for Linux 5.10.0-43-amd64
linux-headers-5.10.0-43-cloud-amd64 - Header files for Linux 5.10.0-43-cloud-amd64
linux-headers-5.10.0-43-rt-amd64 - Header files for Linux 5.10.0-43-rt-amd64
linux-headers-5.10.0-44-amd64 - Header files for Linux 5.10.0-44-amd64
linux-headers-5.10.0-44-cloud-amd64 - Header files for Linux 5.10.0-44-cloud-amd64
linux-headers-5.10.0-44-rt-amd64 - Header files for Linux 5.10.0-44-rt-amd64
linux-image-5.10.0-43-amd64-dbg - Debug symbols for linux-image-5.10.0-43-amd64
linux-image-5.10.0-43-amd64-unsigned - Linux 5.10 for 64-bit PCs
linux-image-5.10.0-43-cloud-amd64-dbg - Debug symbols for linux-image-5.10.0-43-cloud-amd64
linux-image-5.10.0-43-cloud-amd64-unsigned - Linux 5.10 for x86-64 cloud
linux-image-5.10.0-43-rt-amd64-dbg - Debug symbols for linux-image-5.10.0-43-rt-amd64
linux-image-5.10.0-43-rt-amd64-unsigned - Linux 5.10 for 64-bit PCs, PREEMPT_RT
linux-image-5.10.0-44-amd64-dbg - Debug symbols for linux-image-5.10.0-44-amd64
linux-image-5.10.0-44-amd64-unsigned - Linux 5.10 for 64-bit PCs
linux-image-5.10.0-44-cloud-amd64-dbg - Debug symbols for linux-image-5.10.0-44-cloud-amd64
linux-image-5.10.0-44-cloud-amd64-unsigned - Linux 5.10 for x86-64 cloud
linux-image-5.10.0-44-rt-amd64-dbg - Debug symbols for linux-image-5.10.0-44-rt-amd64
linux-image-5.10.0-44-rt-amd64-unsigned - Linux 5.10 for 64-bit PCs, PREEMPT_RT
linux-image-5.10.0-43-amd64 - Linux 5.10 for 64-bit PCs (signed)
linux-image-5.10.0-43-cloud-amd64 - Linux 5.10 for x86-64 cloud (signed)
linux-image-5.10.0-43-rt-amd64 - Linux 5.10 for 64-bit PCs, PREEMPT_RT (signed)
linux-image-5.10.0-44-amd64 - Linux 5.10 for 64-bit PCs (signed)
linux-image-5.10.0-44-cloud-amd64 - Linux 5.10 for x86-64 cloud (signed)
linux-image-5.10.0-44-rt-amd64 - Linux 5.10 for 64-bit PCs, PREEMPT_RT (signed)
linux-headers-5.10.0-28-amd64 - Header files for Linux 5.10.0-28-amd64
linux-image-5.10.0-22-amd64 - Linux 5.10 for 64-bit PCs (signed)
linux-image-5.10.0-28-amd64 - Linux 5.10 for 64-bit PCs (signed)
The both latter (5.10.0-22/28) are those from installation, and  5.10.0-28  runs rock-stable for 2 years now!
a) May i presume, that an update to the latest kernel - linux-image-5.10.0-44-amd64 - is advisable though?
b) It is simply done by  sudo apt install linux-image-5.10.0-44-amd64 ?
c) Should i run an additional  sudo apt install linux-headers-5.10.0-44-amd64  for the headers?
d) How much additional space is approximately needed on disk?
e) Why are kernels 5.10.0-33 - 5.10.0-42  missing in the list above?
F) Is it possible to revert back to kernel  5.10.0-28  if something goes wrong?
Thank you!
#2 2026-06-06 21:49
Re: Updating Q4OS (Gemini) to the latest kernel
a) Yes
b, c) Easier to let Update Manager do the upgrade.
d) About no additional space since an older version will be removed.
e) ?
f) Probably yes (your current version will be kept alongside the new one)
#3 2026-06-06 23:48
Thanks for your answers, hchiper!
I did a test-upgrade, on a backup-disk (from 5.10.0-22), using the  sudo apt install manually.
Together with the headers, that op uses additional ~ 400 MB (no kernel to purge in this case!).
Now i'm trying to figure out where the new 5.10.0-44 kernel-"package" was stored, if its possible to copy it to my main disk, and start the kernel-update there ,locally' (without downloading th package again).
If someone here yet knows, your welcome to assist ;-)
Thanks!
#4 2026-06-09 22:06
No, on my main disk i first downloaded the kernel (linux-image-5.10.0-44-amd64) and then installed it:
$ apt install ./linux-image-5.10.0-44-amd64.deb
That seems to work too, BUT the output of neofetch - unlike to the test-disk - now seems somewhat poorly:
        #####           me@flex7
       ##O#O##          OS: Linux (Unknown) x86_64
       #######          Kernel: 5.10.0-44-amd64
     ###########        Uptime: 3 mins
    #############       Packages: 2021 (dpkg)
   ###############      Shell: bash 5.1.4
   ################     Resolution: 1440x900
  #################     DE: Trinity R14.0.12
#####################   WM: twin
#####################   Theme: Q4OS02 [GTK2], Q4OS01 [GTK3]
  #################     Terminal: konsole
It doesn't recognize it's Q4OS/Debian here! (See also snapshot below)
#5 2026-06-10 08:50
Maybe in /var/cache/apt/archives/
#6 2026-06-10 08:56
I may be wrong, but I believe the reason is that you didn't let Update Manager install the kernel and also tweak some configuration files to add the "Q4OS" references.
#7 2026-06-10 09:41
You should install the official kernel from Debian repositories, we don't recommend installing any inappropriate or unknown kernels.
#8 2026-06-10 13:20
I think i did install the official kernel from Debian repositories in both cases:
Test-disk:
apt install linux-image-5.10.0-44-amd64 > neofetch works fine!
On the main disk: first dowloaded the kernel, then installed it:
- apt download linux-image-5.10.0-44-amd64
- apt install ./linux-image-5.10.0-44-amd64_5.10.257-1_amd64.deb
That really shouldn't make a great difference!?
And all the known tools are delivering the correct informations:
$ hostnamectl
   Static hostname: flex7
         Icon name: computer-desktop
           Chassis: desktop
        Machine ID: <...>
           Boot ID: <...>
  Operating System: Debian GNU/Linux 11 (bullseye)
            Kernel: Linux 5.10.0-44-amd64
      Architecture: x86-64
$ cat /usr/lib/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
$ uname -a
Linux flex7 5.10.0-44-amd64 #1 SMP Debian 5.10.257-1 (2026-05-27) x86_64 GNU/Linux
Edit: just to be clear: The output of the 3 commands above are identcal on both disks!
Only neofetch has an issue after the update made in ,two steps', that's somewhat weird.
#9 2026-06-10 16:45
LoL - i updated my main (Debian 11 based) disk to Python 3.12 (to /usr/local/lib/python3.12) a time ago - which (for some reason) lacks of lsb_release.py - but neofetch relies on it! A simple symlink to it (it's still in /usr/share/pyshared) fixed the issue.
