#1 2026-05-24 02:56
usfarang
Login Picture
How can I set my login picture? I'm using the KDE version. I set it via the settings menu and it shows on the menu but not on the login screen!
Thanks,
#2 2026-05-24 06:57
Re: Login Picture
You could wait until Debian 14 when it will get the later version of Plasma where you can do this via settings
OR
I just changed /usr/share/sddm/themes/breeze/theme.conf
[General]
showlogo=hidden
showClock=true
logo=/usr/share/sddm/themes/breeze/default-logo.svg
type=image
color=#1d99f3
fontSize=10
##background=/usr/share/wallpapers/Next/contents/images/5120x2880.png
background=/usr/share/wallpapers/Next/contents/images/splashback.png
needsFullUserModel=false]
I had copied the file I wanted to use - splashback.png - to the correct locatiion and just edited the path as shown.
#3 2026-05-24 13:15
usfarang
Re: Login Picture
Thanks
