#1 2026-05-23 11:55
Digidoc
Trinity Desktop
Again, I learned a few things.
Ventoy won’t work, it is missing some needed files. Boots and installs from Rufus just fine.
Does Andromeda and 6.7 refer to the same version?
I was trying to re-make Plasma into Trinity. Instead, just start with Trinity. Using [df -h] to check disk space, my usage dropped from 70% to only 54%. This is significant when you have only 16gb of storage.
Many thanks for allowing me to learn.
#2 2026-05-24 21:30
Re: Trinity Desktop
Yes,  Q4OS Andromeda = Q4OS 6.x
Indeed. Q4OS Trinity is just perfect for low ressources systems (and not only low res systems by the way ^^) !
#3 2026-06-21 14:13
supra2jz
Re: Trinity Desktop
Ventoy works perfectly fine for me, no issues with all Q4OS versions basically.
Q4OS running on IBM ThinkPad T60 - C2D T7200, 3GB RAM, 128GB SSD / pockethacks.com / jdmedmparts.com
