#1 2026-05-19 00:19
txm0523
New Install
I just installed Q4OS on an old Thinkpad laptop.
How do I stop all the scrolling of text when I boot up the laptop and when it shuts down ?
Thank you for any help.
txm0523
#2 2026-05-19 06:59
Re: New Install
You cannot actually stop it since it is the start up and shutdown process.
If you mean 'can I hide it?' then yes you can by installing plymouth.
However it does beg the question whether it is a good idea to hide it,
Seeing the process rolling up the screen is useful because it tells you all is working properly.
If that is hidden behind a pretty progress bar which then stops moving you'll have no way of seeing where it has stopped.
Also plymouth just wastes resources.
#3 2026-05-19 08:28
chn97
Re: New Install
sudo nano /etc/default/grub
in the Linux Default section there should "quiet splash loglevel=3" options
Only keep "quiet splash" and remove entries like loglevel etc
This way it'll minimize text flood.
#4 2026-05-19 21:02
Re: New Install
You need to select a profile - just left-click on one, and make sure the “Remove superfluous packages” box is unticked. Then click "Install" button.
#5 2026-05-20 11:45
Re: New Install
I no longer use Plymouth myself, but I seem to recall that you can press [F4] to display the boot logs (toggle between bootscreen and text mode).
Yes, that’s exactly right—one of the reasons I no longer use it: background service, noticeable boot overhead on low-resource machines. I’ve come to the conclusion that Plymouth is clearly overkill for a boot splash.
You might be interested in what I coded for a lightweight bootsplash: https://github.com/seb3773/xbootsplash.
It’s a system for installing single-binary bootsplashes, with ultra-minimal overhead, minimal complexity, and standard initramfs integration. I use it and it works perfectly. However, it’s currently CLI-only; I plan to add a graphical frontend for Trinity.
The system supports static images, animations, a mix of animations and static images, loops, cycles, etc., and manages its own secure package format (since it touches the initramfs, I don’t want it to be used to spread viruses, so the system performs exhaustive security checks and has its own internal signature system).
If you want, I can also provide the test packages I made (many are conversions from Plymouth bootscreens). Or you can wait for the graphical frontend version wink
