#1 2026-05-18 20:17
chn97
Wi-Fi doesn't work on 6.7
Today i installed 6.7 KDE but Wi-Fi list simply doesn't show up. Even if you connect (or not) it during setup. Anyone?
#2 2026-05-18 21:06
Re: Wi-Fi doesn't work on 6.7
Welcome to the forum smile
Do you see wifi list window empty ? A screenshot would be helpful.
#3 2026-05-18 21:24
chn97
I uninstalled but yeah Wi-Fi list says it's unavailable. Restarting network manager won't help. Gemini made me install some mediatek libraries but still no luck. This was not happening in 6.6.
#4 2026-05-18 21:59
#5 2026-05-21 11:08
chn97
Huh? Wi-Fi list shows empty. You don't need screenshots to understand this.
#6 2026-05-21 11:29
There are several ways to display the list of wireless networks. The screenshot tells us exactly what you’re experiencing, so we can try to reproduce and investigate.
#7 2026-05-25 04:56
Digidoc
A quick report. I installed Ver 6.7 and can report wi-fi works correctly for me. This is using both Trinity and Plasma. Use the Prt-Scn button and capture the box where you are seeing the missing wi-fi.
