#1 2026-05-11 09:18
naranja
Possible bug in color appeareance
Hi,
I'm using Q4OS Trinity Aquarius 32bits. When I wanted to change the color of normal tex (the background text listed above text selected) doesn't set on. I apreciate you fix it, please. Thanks so much.
Pd: I'm using one of lite grey themes. I do not remember now which of them, I'm using windows now)
#2 2026-05-11 09:20
Re: Possible bug in color appeareance
Control panel > appearance .. > colors > widget color > standard text > tde color selector > ok > ok
#3 2026-05-11 09:24
naranja
Yes, but doesn't set on the color when I write  on per example L3afpad, use de same color I set for color of up menu text but don't the I decide. Possibly is a bug.
#4 2026-05-11 09:29
Does it set the color for Trinity desktop and applications ?
Leafpad is a GTK application, as they have their own configuration options.
#5 2026-05-11 13:28
naranja
Oh! Now I'm noting that every simple text aplication has its own color appearence. Sorry, I thought that answered to color sistem set. Sorry about my mistake. Thanks for your attention.
