#1 2026-03-20 14:34
raul_comodoro
Sound was working perfectly but few days ago sound does not work
I have installed Q4OS inside Windows. Everything was OK, and sound was working OK. Some days ago works does not work anymore. I've tested all about setting related to but there is no way sound works again.
I don't know what to do. Any suggestion?
May be I could reinstall the system...
Thanks.
#2 2026-03-20 15:34
Re: Sound was working perfectly but few days ago sound does not work
What Q4OS version, desktop environment ?
#3 2026-04-26 19:16
don.cefe
Something similar happened to me. The sound went mute after installing some updates, but only when I login as User; if I login as Admin the sound works well. I'm using Q4OS Live from a USB drive.
#4 2026-04-27 07:14
Happened to me a few times over the years, installing and opening pavucontrol got it working for me again
#5 2026-05-01 20:36
swarfendor437
You are not necessarily going to get sound working out of the box in live mode, especially if it is a dedicated soundcard.
#6 2026-05-01 20:44
swarfendor437
I have a strong reluctance to use Pulse Audio. I have a SoundBlaster Audigy Rx which delivers sound to a Logitech surround sound system. My solution was to create a blacklist.conf file and add HDA Intel to be blacklisted (this is what HDMI audio tends to be identified as on any GNU/LinuxOS. I then install all possible ALSA packages (except for JACK and OSS), along with Qas Mixer, Qas Config and Qas Hctrl. I also had to install the SoundBlaster emulation packages, awesfx and ld10k1. To round it off, installed Audacious and then go to Settings in Audacious, change from Pulse to ALSA, and then in Advanced settings, selected the correct profile (5.1 Surround) from the drop-down list. Once Audacious was setup correctly, all other apps produced sound to the surround sound system. The only thing that cannot be sent to surround sound is streaming media in a browser - this gets sent to the centre stereo speaker.
#7 2026-05-02 02:19
swarfendor437 wrote:
I have a strong reluctance to use Pulse Audio...
Well when I started using Q4OS, the default audio system was pulseaudio.. which was pretty bad, in the latest and testing versions, pipewire & wireplumber, which is default, performed way well in my old notebook. Pipewire/pulseaudio are high level sound servers which work fine in most cases, but I believe your surround sound system might have required these low level configs to work properly.
If you use Firefox then you could try JACK, and if you use chromium then you could try pipewire. Make sure to make a backup of your current config in case the newer configs don't work appropriately. (Sources link provided below)
these might be useful:
https://www.ott.net/audigy-setup/
[HOW TO] Get a SoundBlaster Audigy Rx to work...
It'd be appreciated if you could also post a detailed Tutorial in the Tips and Tricks section smile
