#1 2026-04-26 16:40
bretsim
The stupidest mistake ever
I unzipped a folder and found some of the files had a padlock symbol showing. I searched up about how to get rid of this, and found a command
sudo chmod -vR 777 *path*/*
Unfortunately, I accidentally pressed enter after I'd deleted the placeholder path but before I'd added a path to the document, so it started changing the permissions for every file in /
When I realised what was happening I quickly shut down the terminal window.
Now even sudo won't work.
I realise this is a very amateurish error. Is there any way back short of starting again with a new install? I was hoping the unique way q4os installs alongside windows means there might be an easier way to restore functionality and security (seeing as i guess I made every file in the root accessible to anyone...) but I realise that's optimistic!
#2 2026-04-27 07:16
Re: The stupidest mistake ever
You could try doing a restore from timeshift, which might work
#3 2026-04-27 09:28
We are afraid, the most easy way would be a fresh installation.
#4 2026-04-27 11:52
bretsim
How does this work please?
#5 2026-04-27 11:55
bretsim
I thought that might be the case. I've zipped up all my files and was planning to copy it out to the Windows filesystem, but I can't find any way to do this? On my old Q4os install (alongside Win 7) there was a shortcut on the desktop to access all the storage devices but I can't seem to find any way to get them this time? Any hints?
#6 2026-04-27 13:28
Just insert a USB flash and the storage device appears in Dolphin.
#7 2026-04-28 01:53
bretsim
So there's no way to access the rest of the storage in the machine?
#8 2026-04-28 02:01
bretsim
Is there no way to restore all the permissions to default? Or to copy the filesystem over from a fresh install?
I'm amazed (and quite frustrated) that a modern OS allowed something this destructive to take place on a slip of a finger without even a warning tbh.
#9 2026-04-28 07:46
For this to be possible, you must have created a backup using Timeshift before modifying the permissions (chmod). If you don't have a backup, no restore is possible.
#10 2026-04-28 09:09
You could try changing the permissions back to their previous values (sudo would no longer be necessary if the affected files were granted 777 permissions), but you would then need to know which files were modified and what their original permissions were, which is probably not the case. Even if you could find them, it would likely be such a tedious task that you would probably prefer to reinstall the system completely.
With Linux command line, "sudo" is a warning by itself. Even if the warning were a confirmation message box with buttons, one can still slip on OK instead of Cancel...
That said, I understand your frustration very well.
#11 2026-04-28 15:11
You can try to boot from a Live USB (like Debian Live or Q4Rescue) - If using a manual Live USB, you must mount the environment. If using Q4Rescue, use its built-in chroot script, but ensure the following are mounted:
mount /dev/sdXn /mnt           # the "broken" system partition
mount --bind /dev /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
mount --bind /etc/resolv.conf /mnt/etc/resolv.conf # Essential for Internet
chroot /mnt
Then, we must be sure that apt and dpkg have the minimum required permissions to execute:
chmod 755 /usr/bin/dpkg /usr/bin/apt*
chmod 644 /etc/apt/sources.list
And then, try to reinstall every installed package (will force the system to re-apply the correct permissions and owners for all system files)
apt-get update
for pkg in $(dpkg --get-selections | awk '{print $1}'); do apt-get install --reinstall -y -o Dpkg::Options::="--force-confold" "$pkg";done
(*you will need internet connection for this to work)
Now, if this sucess, some files are not managed by apt or require specific restrictive permissions: Run these manually:
chmod 640 /etc/shadow
chmod 600 /etc/gshadow
chmod 1777 /tmp
chmod 440 /etc/sudoers
chmod 750 /etc/sudoers.d
then exit chroot and reboot. Important: I did not test this procedure *exactly* (encountered this kind of problem once a time, but not at this "level"), so I can't assure it will work, but it's worth trying.
