#1 2026-04-22 21:35
DHOC_TAZH
Easy Effects issues
I have version 8.2.0 installed from flatpak. It's a mess. When I turn it on, and use just the equalizer, I hear the infamous bleep tone going on nonstop. When I turn on more than one effect, the sound almost disappears and sounds muffled.
Should I uninstall 8.2.0 and use the q4os version instead?
Q4OS PCs: 2012 ASUS X54 laptop, B960 CPU, 8 GB RAM, 512 GB SATA SSD-2018 Acer Aspire 7, i7-8750H CPU, 32 GB RAM, 2 TB nvme SSD, both on Trinity DE
#2 2026-04-24 07:56
Re: Easy Effects issues
I'm using Q4OS 4 based on Debian 11, and there's no Q4OS-specific version of easyeffects in Q4OS Software Centre.
Oddly enough, the easyeffects 7.0.0 package is available on the Debian 11 website (https://packages.debian.org/bookworm/easyeffects) but doesn't appear in the list of packages retrieved with `apt list easyeffects`.
Instead of using easyeffects from Flatpak, try installing the package corresponding to the Debian version your Q4OS is based on:
see https://packages.debian.org/search?suit … asyeffects
#3 2026-04-24 08:02
Yes, we would recommend you to remove the flatpak version and install from repositories:
$ sudo apt install easyeffects
#4 2026-04-24 19:03
DHOC_TAZH
That's what I ended up doing, installing from the q4os repo. Works for me now, thanks. smile
