#1 2026-04-05 19:54
Tux Fan
Can I get and use the Q4OS Gemini Windows Installer in 2026?
I want to use an older version because I want to use Gnome 3.38 because I think it looks better than modern desktop environments.
#2 2026-04-05 22:08
Re: Can I get and use the Q4OS Gemini Windows Installer in 2026?
No, it's no longer available.
#3 2026-04-08 09:59
Correction, you can download it here https://sourceforge.net/projects/q4os/f … preciated/ . Please post back a result, once you try it.
#4 2026-04-12 17:39
Tux Fan
Thanks. It worked. The only problems were that I had to install the nvidia drivers through the terminal because installing it through the popup  that appeared when I first logged in didn't work, and when I tried to install Gnome in the initial setup it didn't work, but when I installed it through the Q4OS desktop profiler after everything was installed it worked fine.
Edit: After reinstalling the OS I could install the nvidia drivers through the Q4OS system
