#1 2026-04-04 20:39
krall1q1
problem whit blue man
it was saying bluethooth its not on and ı pressed turn on and its crashed now every time blueman crashes in seconds pls help neutral
and ı am using Q4OS aquarius
#2 2026-04-04 20:59
krall1q1
Re: problem whit blue man
and bluetooth says this (sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
     Active: active (running) since Sat 2026-04-04 21:42:19 +03; 1h 14min ago
       Docs: man:bluetoothd(8)
   Main PID: 1022 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 2191)
     Memory: 1.3M
        CPU: 300ms
     CGroup: /system.slice/bluetooth.service
             └─1022 /usr/libexec/bluetooth/bluetoothd
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: Bluetooth daemon 5.66
Nis 04 21:42:19 q4os-desktop systemd[1]: Started bluetooth.service - Bluetooth service.
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: Starting SDP server
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: src/plugin.c:plugin_init() Failed to init vcp plugin
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: src/plugin.c:plugin_init() Failed to init mcp plugin
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: src/plugin.c:plugin_init() Failed to init bap plugin
Nis 04 21:42:19 q4os-desktop bluetoothd[1022]: Bluetooth management interface 1.22 initialized)
and blue man sayes this
(sudo systemctl status blueman
Unit blueman.service could not be found.)
#3 2026-04-15 17:58
krall1q1
still waiting
#4 2026-04-15 18:03
Please post more info according to https://www.q4os.org/forum/viewtopic.php?id=3502
