Hello,
I am wondering if I am doing something wrong. This is my first foray into Linux operating systems. I chose Q4OS because of its claim of being able to live with Windows side by side without having to create any new partitions.
I downloaded the Windows installer zip file from the website. Unzipped it which created a new extraction folder, then ran the q4os-winsetup.exe. It's been running for way too long, 6 hours+ as I make this support request.
My machine is from 2019, a Dell laptop with 1.2 TB of space. It had been installed with Windows-10, which I recently upgraded to Win-11.
Please see these images:
The CMD prompt window in the first image shows 1.2 TB of free space (this is after Win-11 installation). It also shows that I downloaded the setup zip file at 12:17 pm local time. I clicked the setup executable almost immediately after download. At the bottom right hand corner you can also see the timestamp as 18:25 local time, and you can also see the Andromeda installer stuck at "Remaining time approximately 1h 15 min" message. It's been stuck there for more than 4 hours at least.
The second image gives you the full specs of my machine. 16 GB RAM, i7 chip 6th generation at 2.5GHz Quad core. A fairly robust machine, so I am surprised that the installation is taking so long.
Let me also add that I had done a dry-run of the Q4OS Andromeda in an Oracle Virtual Box, I very much appreciate the look and feel and the fast response of the operating system. It did not take that long in the virtual box to install (to be fair, I allocated only 8 GB RAM and 50 GB hard disk space to the virtual machine when doing the dry run).
Any insights? Thank you for any support you can provide.
Trying to re-attach the images
Welcome to the forum ![]()
We can see your setup has been stuck at the download phase. The download time depends on the speed and reliability of your Internet connection. It should take about 5 minutes at 100Mbps. We would recommend you to cancel setup, reboot, try the setup again and post back the result.
I have a 300 Mbps line, really not sure why it got stuck. That said, the cancel / retry did work. Thanks for quick response.
