#1 2026-03-28 16:42
vort3
Global hotkeys (Ctrl+Alt+Letter) don't work
As requested, making a separate topic. Copied from previous topic:
vort3 wrote:
Global hotkeys simply don't work. I go to global hotkeys tab in keyboard settings and add a few typical Ctrl+Alt+Letter hotkeys, like Ctrl+Alt+T for Terminal (konsole). Pressing the hotkey doesn't do anything. How do I debug? I have no idea. I know keyboard settings can be a mess, for example sometimes things like setting Left Alt + Shift to change keyboard layout somehow break things and now a DE sees this keyboard event as "ISO_Next_Group" rather than left alt or left shift. Also making compose key to be Right Alt can break things that are bound to Alt+Letter keys. I'm not sure what exactly is the problem here, but for reference I do use left alt + shift to switch layouts (I use 2 layouts) and I do use right alt as compose key. Anyone have any idea why Alt+Ctrl+T can't launch my Terminal?
The original topic was here: https://www.q4os.org/forum/viewtopic.php?id=6017
The global hotkeys tab I'm referring to is found here:
settings:/Accessibility/ , choose "Keyboard Shortcuts" from there, go to "Command Shortcuts" from there.
In the list I expand "Programs" category and find "Konsole". On the bottom I press "Custom" button, in a new window that appears I click on "Primary" field and type Ctrl+Alt+T.
The hotkey appears in the "Command shortcuts" tab. I press apply, ok, close the window.
I press Ctrl+Alt+T. Nothing happens.
#2 2026-03-28 19:25
Re: Global hotkeys (Ctrl+Alt+Letter) don't work
Yes, that's the correct way that works fine here. You may only need to re/login/boot after the shortcut configuration. Does it work for you after login again ?
#3 2026-03-28 20:58
vort3
I'll try once I don't need any critical processes and have the opportunity to reboot, thanks.
However, I expected this to work without reboot, immediately after hitting "apply"…
I'll try to not forget and report here if it works.
UPD: Issue solved, logout and login worked, thanks! Is this intended behavior that a logout is required? Is it a bug? Is there a way to "force" hotkeys to be updated without logout?
#4 2026-03-28 21:18
It's no bug just Trinity desktop design. Underlying daemon needs to be restarted.
#5 2026-03-29 08:07
vort3
Which daemon is it? I'll try to restart it with systemctl.
Also I'm not sure what's causing it, but now when I press (or release) left Alt, dekstop icons "flicker". They disappear for a short time and appear again. This is annoying… Pressing any combination which involves the left Alt key does this. I checked, it only happens when desktop is focused (or, alternatively, when no other window is focused). Any idea how to troubleshoot?
Pressing Super_L triggers Alt+F1 so also makes desktop icons flicker.
#6 2026-03-29 14:41
Please refer to Control Panel > TDE Components > Service Manager. However, some TDE services are integrated into the desktop code and can only be restarted by restarting the entire desktop environment.
vort3 wrote:
... when I press (or release) left Alt, dekstop icons "flicker". They disappear for a short time and appear again. ...
Yes, we can confirm this issue. It looks like a Trinity native issue, but we are not sure yet, so we need to investigate a bit.
