#1 2026-03-26 14:39
antonej
lxqt but not working
Hallo,
i was using plasma but my laptop is slow so i wanted to try lxqt. I installed it using desktop profiler and once rebooted plasma was still on.
Browsing application i can see lxqt app installed along with plasma ones but plasma is the windowmanager active.
How can get rid of plasma and use lxqt.
thanks
Antonio
#2 2026-03-26 14:40
Re: lxqt but not working
Welcome to the forum smile
Log from Plasma session out, select LXQt session on the login screen and log in.
#3 2026-03-26 15:17
ydek
What are the specifications of your laptop/computer?
The Trinity environment might work well, but if you're happy with LXQt, stick with it
#4 2026-03-26 15:37
antonej
thx, and thank you for your quick answer
ok, i got it, well lxqt is so minimal, from plasma to lxqt seems to go back in the past :=) but is also very very fast.
mmhh
#5 2026-03-27 09:41
antonej
Its a hp laptop with celeron CPU and 4 GB RAM. I'll try trinity, the switch from
plasma to lxqt was  shocking smile
