#1 2025-11-18 11:15
Q4Riv: Plymouth Theme for Q4OS
Q4Riv – A minimal, sleek Plymouth theme for Q4OS
Q4Riv is a smooth, modern Plymouth theme designed to give Q4OS a clean and elegant boot experience — no clutter, just a calming luminous animation while your system wakes up.
Downloads
Both installers are attached below:
  • .deb package — install on any Debian-based Q4OS setup
  • .qsi package — Q4OS GUI installer for one-click setup
GitHub (source + full instructions):
https://github.com/TheAsmitKid/Q4Riv
Installation
.deb method
sudo apt install ./q4riv-plymouth-theme_1.0-a1_all.deb
.qsi method
Run the Q4OS Installer by double-clicking the .qsi file.
Once installed:
sudo plymouth-set-default-theme -R q4riv
That’s it — enjoy the smoother boot!
Feedback & suggestions appreciated tongue
– theasmitkid
#2 2025-11-24 14:06
Re: Q4Riv: Plymouth Theme for Q4OS
Initial Release is out!
#3 2025-11-24 20:38
Some screenshots would be rather welcome... cool
#4 2025-11-25 07:46
screenshots while kernel is booting? um I'd appreciate if someone with a Q4OS virtual machine could share a screenshot smile
#5 2025-11-27 22:19
Worst case scenario it could even be phone pics... neutral
#6 2025-12-04 09:39
Added; Drawn in Kolourpaint tongue
#7 2025-12-05 15:45
Thank you. smile
#8 2026-03-26 13:06
BUGOR
I replaced my logo with a more colorful one. under root
sudo update-alternatives --install /usr/share/plymouth/themes/default.plymouth default.plymouth /usr/share/plymouth/themes/q4riv/q4riv.plymouth 100
sudo update-alternatives --config default.plymouth && sudo update-initramfs -u
Check
read -p 'Do you want to test the theme? (Y/N)'
if [ '$REPLY' != 'n' -a '$REPLY' != 'N' ] ; then
echo
echo 'Running 10-second test...'
sudo plymouthd ; sudo plymouth --show-splash ; for ((I=0; I<10; I++)); do sleep 1 ; sudo plymouth --update=test$I ; done ; sudo plymouth --quit
fi
exit
