Hello !
Here’s the app that probably nobody was waiting for, but I made it anyway :-p
In my quest to learn tqt3 and its subtleties, I’ve been having fun trying to port a few applications (your suggestions are welcome, by the way ^^) to tqt3, to have “native” Trinity versions. My latest “victim” is balena Etcher, a very popular tool for flashing ISOs, disk images, etc.
Why port it to tqt3 when it already works under Trinity? Simple answer: balena Etcher, despite its obvious strengths—ease of use and robust security checks—is an Electron app… which means it often consumes hundreds of megabytes of RAM just sitting idle… Not very “Trinity DE” philosophy, is it?
Since fully porting an Electron app is generally a monstrous task, I took a different approach: I decided to clone the graphical interface (which, by the way, was a fun tqt3 exercise, since Etcher’s UI isn’t exactly “standard”). I then rewrote everything in C++, carefully following Etcher’s logic and methods to preserve not just its looks, but also its qualities and features. The result is a near-perfect clone, with a few intentional visual tweaks (some icons are slightly different or reimagined for this Trinity-only version), all in a 140 KB binary (compared to… 228 MB for balena Etcher ^^).
https://github.com/seb3773/tdeflasher
Debian package attached. Feedback and criticism welcome ![]()
screenshots:
That's really cool. Good work.
Uber-cool, indeed. I'm partial to Rufus for this purpose (under Windows) but really appreciate your achievement. ![]()
+1 .. Really cool
Hello !
Here’s the app that probably nobody was waiting for...
That's not correct
- i did wait for it!
Until now i did the flashing allway with Rufus... will utilize it at the end of the year, when the support for Gemini runs out.
However, at this moment i'm not at all sure, whether it will then be Q4OS 5, 6,... or maybe even 7 ![]()
