#26 2026-03-09 14:49
Re: Q4OS TDE: acoustic (ogg) System Notifications fail
Please run in terminal:
$ ls -ld /run/user/1000
$ ls -l /run/user/1000
$ echo $XDG_RUNTIME_DIR
and post back the output
#27 2026-03-09 15:02
Found a similar type of problen here: https://q4os.org/forum/viewtopic.php?id=2475
#28 2026-03-09 15:07
~\> ls -ld /run/user/1000
drwx------ 7 me me 200  9. Mär 14:48 /run/user/1000
~\> ls -l /run/user/1000
insgesamt 4
srw-rw-rw- 1 me me   0  9. Mär 14:48 bus
drwx------ 3 me me  60  9. Mär 14:48 dbus-1
drwx------ 2 me me  60  9. Mär 14:48 dconf
drwx------ 2 me me 140  9. Mär 14:48 gnupg
-rw------- 1 me me 185  9. Mär 14:48 ICEauthority
srw-rw-rw- 1 me me   0  9. Mär 14:48 pk-debconf-socket
drwx------ 2 me me  80  9. Mär 14:48 pulse
drwxr-xr-x 5 me me 140  9. Mär 14:48 systemd
~\> echo $XDG_RUNTIME_DIR
/run/user/1000
#29 2026-03-09 15:30
After you have edited your post #25, the messages are correct. Is it possible your disk turns read only and revert back after reboot ?
#30 2026-03-09 15:52
No, i don't think so - the DCOP error persists, not possible to rebuil tdesyscoca:
~\> tdebuildsycoca
[tdebuildsycoca] tdebuildsycoca running...
[2026/03/09 15:09:56.751] [tdebuildsycoca] Reusing existing tdesycoca.
~\> sudo tdebuildsycoca
[tdebuildsycoca] Warning: tdebuildsycoca is unable to register with DCOP.
[2026/03/09 15:10:14.281] [tdebuildsycoca] Reusing existing tdesycoca.
as well as the sound-notification issue.
#31 2026-03-09 17:24
~\> tdebuildsycoca
We don't see any error, tdesyscoca appears to have been built correctly. The warning is quite normal at the first run as there are no DCOP server running for root. As you run the command once again, it will get off.
#32 2026-03-10 14:20
So i went to /opt/trinity/share/sounds again and observed, that the ogg-files have an 'empty' file icon (withaout a loudspeaker, like the wav) - See the first two snapshots attached.
Thought: maybe here's something missing and decided to add the 'missing' ogg filetype 'Ogg File' selected the appropriate icon, and 'artsplay' as application.
That was a mistake! Now booting up, it is waiting first several seconds at the (5th) Desktop Icon, and then com several error massage boxes "Sorry - KDesktop: Could not find mimetype  application octet-strem'
These messages do occur also subsequently opening konqueror or any other k-app (see snaphot 3).
It's not possible to start (double-click) the 'Control Panel' any more, even worse: it crahes (-> snapshot 4).
However, i can start 'tdecmshell kcmnotify' from the console.
Ok, max of uploades reached, i'll start a new post...
#33 2026-03-10 14:42
I would like to mention, that every other non-k app is still workin withot any issue.
Long story short: Is it possible to
A)  reset TDE's mime-database,  or
B)  copy/transfer it from a fine (backup) installation/disk,  or
C)  correct it manually
Thank you!
Edit: or maybe i should go to https://www.trinitydesktop.org/ and ask there?
Edit2: Added a last snaphot.
#34 2026-03-10 17:46
Important update:
Found the solution here: https://wiki.trinitydesktop.org/Tips_And_Tricks  in the last paragraph:
"Unable to find mime type application/octet-stream": This error can occur due to a known bug with the TDE MIME system.
i utilized Method 1 to get rid of all errors and issues.
#35 2026-03-10 18:21
So did you actually find the ultimate fix for the OP ?
#36 2026-03-10 22:05
Yes, ALL errors were fixed after adding the "octet-stream" mime (via 'tdecmshell filetypes')!
#37 2026-03-10 22:10
Thanks for valuable reporting and sharing the solution smile
The main question is, what action has the issue triggered.
#38 2026-03-11 00:18
I have absolutely no clue. Since my sound system isn't allways on, and there was no general sound issue at all, i can't even say when it happened.
#39 2026-03-11 08:52
Would you please run commands and post the output:
$ cat $HOME/.trinity/share/mimelnk/application/q4os-octet-stream.desktop
$ cat $HOME/.trinity/share/mimelnk/application/octet-stream.desktop
#40 2026-03-11 12:39
~\> cat $HOME/.trinity/share/mimelnk/application/q4os-octet-stream.desktop
[Desktop Entry]
Comment=Ogg File
Hidden=true
Icon=audio-x-generic
MimeType=application/x-kdeuser2
OnlyShowIn=TDE;
Patterns=*.ogg;*.OGG
Type=MimeType
X-Ubuntu-Gettext-Domain=desktop_tdelibs-trinity
~\> cat $HOME/.trinity/share/mimelnk/application/octet-stream.desktop
[Desktop Entry]
Comment=
Hidden=false
Icon=
MimeType=application/octet-stream
Patterns=
Type=MimeType
The 'ogg' patterns in the first (q4os-octet-stream.desktop) seem somewhat strange?
#41 2026-03-11 12:49
Yes, it's not the original file intended to depreciate the "octet-stream" bug, so something had to rewrite this file. The original you will find in:
/usr/share/apps/q4os_system/share/q4os_home.tar.gz/.trinity/share/mimelnk/application/q4os-octet-stream.desktop
What happens, if you delete your fix "$HOME/.trinity/share/mimelnk/application/octet-stream.desktop", and rewrite q4os-octet-stream.desktop back with its original, so it should be:
[Desktop Entry]
#defines mime type, the same as /usr/share/mime/packages/*.desktop
#override the default trinity octet-stream mimetype
Comment=Unknown
#Icon=
#X-TDE-PatternsAccuracy=0
#Patterns=
Type=MimeType
OnlyShowIn=TDE;
#42 2026-03-11 14:01
The original looks a bit different here: Not possible to copy&paste from ark-preview, so please see screenshot.
I will now save the current q4os-octet-stream.desktop and unpack the original from q4os_home.tar.gz.
Just a minute...
Edit: That results in the original ogg-Sound issue!!
Now i' try the version that you postet above:
[Desktop Entry]
Comment=Unknown
#Icon=
#Patterns=
Type=MimeType
OnlyShowIn=TDE;
Just a minute please...
No, the original ,No ogg-Sound in TDE' issu remains also with your version. Only the weird "octet-stream - ogg" crossover version i posted above seems to work here.
Hopefully that's no breeding ground for other strange effects in the future ;-)
Anyway, i will add a new Q4OS on my disk(s) at the end of this year, when Gemini's support ends (not yet sure, whether it will be Q4OS 5,6 or 7 then)...
#43 2026-03-11 15:11
We are now confused about what works and what doesn’t. Could you please post a few combinations here along with results ?
1.
q4os-octet-stream.desktop / A
octet-stream.desktop - present
result: ??
2.
octet-stream.desktop - deleted
result: ??
3.
q4os-octet-stream.desktop / B
result: ??
4.
result: ??
q4os-octet-stream.desktop / A ... weird version with .ogg reference inside
q4os-octet-stream.desktop / B ... original version extracted from the tgz archive
Don't forget re-login between the tests.
#44 2026-03-11 16:01
Regarding ~/.trinity/share/mimelnk/application/q4os-octet-stream.desktop:
1) The ,crossover' version which i have/had:
[Desktop Entry]
Comment=Ogg File
Hidden=true
OnlyShowIn=TDE;
Type=MimeType
-> Works!
2) the ,origial' version of  /usr/share/apps/q4os_system/share/q4os_home.tar.gz (date: 10.10.2001):
[Desktop Entry]
Comment=Unknown
Hidden=false
#Icon=
#Patterns=
Type=MimeType
OnlyShowIn=TDE;
-> The ogg-issue in TDE is back!
3) The version which you posted in #41 - which differes slightly from the version in q4os_home.tar.gz:
[Desktop Entry]
Comment=Unknown
#Icon=
#Patterns=
Type=MimeType
OnlyShowIn=TDE;
-> The ogg-issue in TDE is still there!
4) Reverted back to 1) -> It's working fine again!
Each time i changed q4os-octet-stream.desktop, i rebooted!!
#45 2026-03-11 16:07
Well, did you have “octet-stream.desktop” - the fix you previously added - present or deleted during all the tests ?
#46 2026-03-11 16:22
it was allways present - i missed the hint to delete it in your post. Just a minute...
I can confirm: deleting (well, renaming~) octet-stream.desktop, and with the original q4os-octet-stream.desktop (from /q4os_home.tar.gz) it does work (too)!
And since it looks much better for me than the quirky 'mixture octet-stream+ogg' crossover version,
i'll leave it that way! Many Thanks!!
#47 2026-03-11 17:17
Perfect. If you would get any new info about how "q4os-octet-stream.desktop" might have changed, do not hesitate to post here.
Another odd thing is that your "/usr/share/apps/q4os_system/share/q4os_home.tar.gz" file is not the current one as it should be. Do you have your system up to date ?
Run:
$ md5sum /usr/share/apps/q4os_system/share/q4os_home.tar.gz
$ dpkg -S q4os_home.tar.gz
and post back.
#48 2026-03-11 21:25
here the results:
~\> dpkg -S q4os_home.tar.gz
q4os-base: /usr/share/apps/q4os_system/share/q4os_home.tar.gz
~\> md5sum /usr/share/apps/q4os_system/share/q4os_home.tar.gz
d39f0ed8383121ae00b0a3e91a52d320  /usr/share/apps/q4os_system/share/q4os_home.tar.gz
The system was built with Version 4.12 (kernel 5.10.0-22) and updated to 5.10.0-28 during installation.
#49 2026-03-11 21:33
Checksum for the current, full updated file should be:
2d607a4d06d36e1ed571327e0a9c1755  /usr/share/apps/q4os_system/share/q4os_home.tar.gz
Please run and post back:
$ apt policy q4os-base
Update system:
$ sudo apt update
$ sudo apt full-upgrade
And then check the checksum again:
#50 2026-03-11 22:02
~\> get-q4os-version
4.12.1-n1
~\> apt policy q4os-base
q4os-base:
  Installiert:           4.19.1-a1
  Installationskandidat: 4.28.2-a2
  Versionstabelle:
     4.28.2-a2 501
        501 http://q4os.org/q4repo q4os-4-0-cn/main amd64 Packages
 *** 4.19.1-a1 100
        100 /var/lib/dpkg/status
I've had bad experiences upgrading system to kernels 5.10.0-33 (osprober didn't find Windows to boot in) and 5.10.0-37 (with 1000s of © on the screen and buzzing from the grafics).
So , the "apt full-upgrade" i'll firstly try only on a virtual- or test installation (at the next weekend)!!
