#1 2026-02-17 19:48
Armbroke
Wifi connect
HI all,
As you might suspect, I can't connect my q4os to wifi/internet.
Long story short, I made a scratch installation. When I then tried to run Desktop profiler the system found no wifi; I clicked the network icon and
It installed automatically, followed by the very long profiler installation. Looking good so far.
But then, trying to run Firefox there is no internet.....?
I use an external wifi adapter WUA-0614 which has worked flawlessly for a long time, as well as today as described above. Nothing was changed
after that. So what am I missing ?
I have used q4os for some time, and my experience is that most program installations are pretty straightforward.
Please put me on track again
Peter
#2 2026-02-17 21:45
Re: Wifi connect
Armbroke wrote:
HI all,
Peter
Not an easy one... :-/ Maybe the network management service didn't carry over your credentials or DNS settings after the profiler installation ?
It's possible that the system toggles a software switch to "Airplane Mode" if there was a problem during installation, so try: rfkill list
if wifi is soft blocked, try: rfkill unblock <wifi name>
-Try to restart network manager: sudo systemctl restart networkmanager
Something possible too, is that your wifi card use non-free firmware, and maybe it not have been fully initialized for the desktop environment after the profiler installation ? In this case, you can try:
sudo apt update && sudo apt install firmware-misc-nonfree
** of course, you will need  a connection to do that, can you connect with ethernet ?
My two cents..maybe Q4OS Team can propose something better smile
#3 2026-02-17 21:54
Re: Wifi connect
We would recommend you to follow https://www.q4os.org/forum/viewtopic.php?id=4698 and post back the result.
#4 2026-02-17 21:58
Armbroke
Re: Wifi connect
Thanks SEB , will look into your suggestions, and of course report outcome.
What bugs me is that this was working fine until a couple of days ago until I was forced to reinstall it all.
Peter
#5 2026-02-20 10:30
Re: Wifi connect
@Armbroke
You posted the same post in the thread mentioned by q4osteam and I responded there.
But better to continue the discussion here.
