#1 2026-01-28 21:16
1-DOT.C0M
Simple Way to Change Cursor Size
Cursor size is typically set to 24 (too small for me).
To increase the size in Q4OS Trinity (X11), open Terminal and type:
echo "Xcursor.size: 48" >> ~/.Xresources
Log out and log back in to see the change and adjust number accordingly with nano editor.
#2 2026-02-09 21:19
Re: Simple Way to Change Cursor Size
You can even skip the logout. TDE (like KDE3) uses Xcursor, so the size can be changed "on the fly":
echo "Xcursor.size: 48" | xrdb -merge
The effect is immediate for most X11 apps—no need to log out. (maybe need to restart some TDE apps only)
#3 2026-04-27 08:39
JimT777
I tried the "on the fly" method and it did not work for me.  So I tried the method that required a log out and log back in that that one worked.  Thanks guys!
#4 2026-05-01 21:13
swarfendor437
Thanks for this. I changed things in Trinity following advice on a Trinity mail list about installing some additional cursors (that don't get recognised) and to do similar steps to what you have given - yours is much shorter and quicker.
