#1 2016-03-31 00:31
RichardPr
How to arrive at wifi password?
Hi, does anybody conscious how to get wifi watchword from domicile router?
#2 2016-03-31 01:38
Re: How to arrive at wifi password?
log in as admin and read it.
#3 2016-03-31 03:37
JimW
It depends on your router. Generally you login at 192.168.1.1, but I think it is different for some routers. You will need the admin name and password. If it has not been changed you should be able to locate what the factory setup is by doing a web search for the router name and model number. Once you are logged in to the router you should be able to find the wireless setup area which will show the SSID and password.
