#1 2026-01-29 19:41
itsoulos
Why the system takes too long to shutdown?
Hello all,
sometimes the Q4OS system requires many seconds to completely shutdown due to some user@1000.service!
Is this normal?
Giannis
#2 2026-01-29 21:55
Re: Why the system takes too long to shutdown?
No it's not normal. How many seconds ?
#3 2026-01-30 06:57
itsoulos
90 seconds
#4 2026-01-30 14:09
itsoulos
This  problem occurs in my desktop running X11. This is not present in my Tuxedo Pulse that runs wayland
#5 2026-01-30 14:30
AI says, and it's consistent with what we assume:
Systemd is trying to stop the user session for UID 1000 (usually the first normal user) and something in that user session is hanging during logout/shutdown.
What’s usually causing it, most common culprits:
- A stuck user process (browser, Electron app, VS Code, Java, Python, etc.)
- A systemd user service that doesn’t exit cleanly
- FUSE mounts (sshfs, rclone, gvfs)
- Lingering user services still running after logout
- Flatpak / Snap apps misbehaving
Systemd waits (default ~90s), then complains.
Quick ways to diagnose
See what’s still running for that user
$ loginctl user-status 1000
This usually points straight at the offender.
Check failed user services
$ systemctl --user list-units --failed
Or logs:
$ journalctl --user -xe
#6 2026-01-30 14:45
itsoulos
here is the output for loginctl:
https://pastebin.com/5WZTj9VB
and here for systemctl
https://pastebin.com/vLuezG7i
