#1 2026-01-19 17:02
supranova
supranova
buenos dias , soy nuevo en el mundo de linux, tengo un ordendor viejo compac 500 con un giga de ram al que le intalado q4os , he bajado kodi por el terminal , pero la version que baje no abre con las caracteristicas del ordenador , me gustaria que me ayudaseis a bajar una verison mas antigua de linux como la version 19 para windows , me gustaria que me proporcionan una guia de instalacion de version de kodi 19 o similares , gracias de antemano
Edit by admin: Google translate:
Good morning, I'm new to the world of Linux. I have an old Compaq 500 computer with 1GB of RAM on which I've installed Q4OS. I downloaded Kodi via the terminal, but the version I downloaded doesn't run on my computer. I'd appreciate your help in downloading an older Linux version, such as version 19 for Windows. I'd also appreciate it if you could provide me with an installation guide for Kodi version 19 or similar. Thank you in advance.
#2 2026-01-19 19:55
Re: supranova
Welcome to the forum smile Please post in English, Google translate is a possible way.
#3 2026-01-19 22:53
Re: supranova
Open a Terminal and simply run `$ sudo apt install kodi`. You'll need a working Internet connection.
Depending of your Q4OS version it will install Kodi 2.19, 2.20 or 2.21.
Have also a look at the hardware requirements for Kodi.
#4 2026-01-21 15:35
supranova
Re: supranova
Thank you, I will do it again, and if I have any problems I will contact you again.
