For some reason, touchpad scrolling doesn't work on 6.4. It worked on previous versions (3.6-5.8). The scrolling option is checked in the settings. The touchpad itself works.
I think on Q4OS 6 TDE, by default it's configured to use two finger scrolling instead of edge scrolling like previous versions of Q4OS TDE
If you're talking about horizontal scrolling, it's probably a tde bug
https://mirror.git.trinitydesktop.org/g … issues/248
https://www.q4os.org/forum/viewtopic.php?id=5687
Yes. Thank you!
You can change the behaviour in the settings: tdecmshell touchpad
I got it. I found it. Problem solved. Thank you!
