#1 2025-12-06 20:51
erikth
About Flatpack.
What vil work best - installing a program via Q4OS Software Centre og via Discover Flatpack?
#2 2025-12-07 07:35
Re: About Flatpack.
This is a question to which there is no right answer.
My personal preference is to use Debian packages or packages in Software Centre - irrespective of whatever distro I am using.
I have only ever used one flatpak package and that was because there was no choice at all in the normal package channel.
Flatpaks tend to contain newer versions, or as I said, software that it not in the normal channel - mainly because the developer has chosen to not provide for that.
Be aware that flatpaks do bring their own problems and they can take up a lot of space.
Others may differ in their opinion - ultimately it is your choice.
#3 2025-12-07 11:25
erikth
Re: About Flatpack.
I Thank you for your ansver.
