I love ungoogled chromium, so do many other users, (also mentioned by someone in a distrowatch review)
Since the .deb isn't available, installing it is a bit painful as you have to download .tar.xz then extract it, move executable to required path and create .desktop entry everywhere
So I'd love to see ungoogled-chromium as a qsi on Q4OS.
Also, a Q4OS portable apps installer so you can easily install it a .tar.xz or appimage.
Yes, you could also start a new project on Github, we would support such a project with patches. As a template, you can use any of these projects https://github.com/orgs/q4os-installers/repositories
