#1 2016-03-26 13:16
TDEInit could not launch ...
I am trying to get a python script running from an application launcher on the desktop, I can get it working by prefixing "python " before the application name, but cannot get it to run the script by using the script name on it's own. I have the file executable and it will run using cli "./scriptname.py"
what I am trying to achieve really is to get the name of my script showing in top to measure resource usage, I could track python, but, if there are any other python usages it will merge the information (I think).
Any idea's on how to get this to work?
#2 2016-03-26 15:45
Re: TDEInit could not launch ...
We don't exactly understand the problem. If we create simple executable bash script 'test.sh' and related shortcut on the Desktop -> Create new -> Link to application -> Application tab , it works fine.
Shortcut has been created as follows:
[Desktop Entry]
Exec='/home/adminq/test.sh'
Icon=application-x-executable
Name=Verknüpfung zu Programm
StartupNotify=true
Terminal=false
Type=Application
X-TDE-SubstituteUID=false
#3 2016-03-26 16:01
I can use bash scripts fine, it is python scripts that don't seem to wok giving me a "TDEInit could not launch ..." Erorr message. My .desktop file looks the same as you have posted (with different names obviously).
I have the proper shebang and have tried both "#!/usr/bin/env python" and "#!/usr/bin/python" and neither seem to work. Could you try with a python script and let me know if I need to maybe change the "Type" or some other variable.
#4 2016-03-26 16:21
Create file test.py:
from subprocess import call
call(["kdialog", "--msgbox", "TEST"])
Make it executable and create shortcut as we have described above. It works fine here.
#5 2016-03-26 16:38
Thanks, I tried it and it works without issue. Does the TDEInit log output somewhere that I could check for the reason it is failing on my script?
#6 2016-03-26 20:53
I found the problem, I had chmod'd the wrong file!! roll
#7 2016-03-27 22:24
you and me both lol
